P1706 PNP Switch, ECM terminal #44 only 4.8 V
Old Oct 13, 2012 | 02:23 PM
redred's Avatar
Hello,
I got the p1706 code on my 2001 maxima (neutral position switch). I disconnected the switch at the harness. I measured the voltage on ECM terminal 44. It is supposed to be battery voltage but is only 4.8V.
Has anyone seen this before? I am wondering if the issue is the ECM and not the PNP switch since it is not getting the proper voltage.
Look at the EC manual page 600 to see what I am talking about. Any thoughts
Old Oct 13, 2012 | 02:43 PM
DennisMik's Avatar
The voltage reading is interesting. I would expect to see something like 9 volts instead of 12. Your reading is something to consider.
Are you measuring at the ECM itself or the wire harness plug that goes on the switch? Measuring on the ECM is real easy to be on the wrong pin.
Did you measure continuity on the neutral position switch with the trans in neutral? I'd do this first because a switch is more likely to fail then the ECM.
Old Oct 13, 2012 | 02:51 PM
redred's Avatar
Hi Dennis. I measured the voltage on the harness. I didn't check the switch because I assumed it was bad. I have gotten the code in the past. i would generally reset and it would go away for months but now it would come back after a few days.
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
