Anybody with 2K Max/Cali emissions that had problems after Y-pipe?
Old Jan 8, 2002 | 10:56 PM
Sly's Avatar
Sly
For a few months I've had a Stillen Y-pipe on my car that didn't fit exactly right and was leaking, apparently causing other problems. Recently I replaced it with a Cattman Y-pipe which fixed the leak and sounds much better, but I still get knocking on moderate acceleration. Also, my fuel economy hasn't gone back up to where it was before the Y-pipe, and even at full throttle it seems to not pull like it should. I was wondering if these issues are caused by faulty ignition coils or something else? My Max is a mid '99 build with Cali. emissions. Could it be that I damaged an O2 sensor during the install? It just seems that everything was fine until I removed the stock Y-pipe.
Anybody else have similar experiences?
Old Jan 8, 2002 | 11:07 PM
irvine78's Avatar
Re: Anybody with 2K Max/Cali emissions that had problems after Y-pipe?
when i first installed my y-pipe, it was leaking only cuz i didn't align the top gasket properly and it got pinched. after fixing that, i didn't have any problems with my y-pipe whatsoever.
Old Jan 9, 2002 | 07:44 AM
UMD_MaxSE's Avatar
Got Bent?
faulty coils could cause lack of power or reduction in gas mileage....
Old Jan 9, 2002 | 09:03 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i just put on my cattman about a month and had some leaking, so i just took it back down, used new gaskets and used some patience and now everything sounds good. the knocking or banging could be the y pipe hit against the exhaust bracket. its black and has 8 bolts. im planning on getting different bolts, but for now its just on and the banging has gone away. i kept the negative post over night and my gas mileage is around the same if not up a little bit.
Old Jan 9, 2002 | 09:26 AM
Sly's Avatar
Sly
It's definitely engine knock (ping) and not the exhaust hitting the vehicle crossmemeber. I fixed that by using two washers at each bolt to offset that bracket from the body. Now it only bangs on hard launches in first gear. Like you, I need to get longer bolts before I put any more washers under there.
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
carid
Sep 9, 2015 05:06 AM
