Test Pipe
Old Oct 21, 2012 | 01:59 PM
ZzzZSlow's Avatar
Test Pipe
Hey guys, I've noticed in my research that a Megan Racing Test Pipe is to big. The OEM cat is 12.5 inches longer and the Megan racing one can be from 13.5-14.5. Therefore does anyone know of any other test pipes to get? I've found this one but it doesn't say how long it is! http://www.ebay.com/itm/2000-2003-NI...1520d8&vxp=mtr
Old Oct 21, 2012 | 02:09 PM
ShocknAwe's Avatar
the one linked will fit but you dont want one that cheap, the bolts in that kit are probably grade 5 at best. I would get this http://www.ebay.com/itm/Nissan-89-98...d2f4c1&vxp=mtr
Old Oct 21, 2012 | 02:16 PM
ZzzZSlow's Avatar
I have a 03 Maxima. Will it fit?
Old Oct 21, 2012 | 02:23 PM
ShocknAwe's Avatar
Should but not 100% certain. I dont know the length of your OEM cat that the test pipe is to replace. The oversized will not fit, that I am certain of. Your cat should measure a little over 12" no?
Old Oct 21, 2012 | 02:27 PM
ZzzZSlow's Avatar
Stock cat measures up to 12.5inches!
Old Oct 21, 2012 | 02:30 PM
ShocknAwe's Avatar
it should be 12 3/8". It should fit but I cant tell you for certain. Search around on here. A lot use the 3" test pipe and it is the same size as the Cattman fastcat just a lot cheaper. I dont know why they sell oversized test pipes. Beats me but I am sure there is a good reason
Old Oct 21, 2012 | 02:31 PM
Rods03Max619's Avatar
Here is one 12.5''.....
http://www.ebay.com/itm/95-99-MAXIMA...96facd&vxp=mtr
Old Oct 21, 2012 | 02:32 PM
ZzzZSlow's Avatar
That's for a 95-99 though... lol
Old Oct 21, 2012 | 02:33 PM
ShocknAwe's Avatar
it could be for a 1950 ford but if it is the right size it is the right size. Really dont think it is 12.5" though.
Old Oct 21, 2012 | 02:35 PM
Same ****, I thought you knew...same length.....
Old Oct 21, 2012 | 03:25 PM
TunerMaxima3000's Avatar
wouldnt buy one that says 2000-2003, theyre are a bunch of variations.
Old Oct 21, 2012 | 03:27 PM
cjandura's Avatar
The megans suck yes they are too long but the 240 one fits
Sent from AznRyan's iPhone
Old Oct 21, 2012 | 09:53 PM
ZzzZSlow's Avatar
Hmm, I posted WTB on JDMofchicago because I know alot of guys have 240sx's and someone has he wants to sell me for $10 bucks its 12.5 inchs but Idk if its 2.25 inch or 3 inch... I'll pick that up see if it works!
Old Oct 21, 2012 | 10:02 PM
ZzzZSlow's Avatar
But he put that its a non resonated one.. I'm guessing none of the test pipes out there have resonators ..
Old Oct 22, 2012 | 02:03 AM
Mr. Blue Sky's Avatar
that non resonated one will just be a 12.5" pipe(literally) with the flanges at the ends of it
Old Oct 22, 2012 | 09:59 AM
schmellyfart's Avatar
4th gen maxima test pipe will fit as will a 240sx test pipe.
Don't believe us? Search.
Old Oct 22, 2012 | 01:28 PM
ZzzZSlow's Avatar
Is this a bad thing?? And he told me it's 2.5inch and 12.5inches long so it'll work?
Old Oct 22, 2012 | 01:45 PM
not a bad thing. the main advantage that a resonated test pipe would have is that it would deaden a little bit of the extra noise and possible rasp that comes with removing the main cat. It will work with the car, and will not cause any issues(other than a possible code for low cat efficiency, or O2 sensor code). That issue mainly happens when you remove the cat, but there are solutions for that too. You can use spark plug anti foulers to help resolve any O2 codes
Old Oct 22, 2012 | 02:02 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
I have no rasp, and have a 3 inch test pipe on mine. aside from that I use an o2 sim on the secondarys. I purchased mine from Mandrel bent solutions. Ordered the 3 inch pipe and flanges, as well as a bung to add my wideband, and just had a friend weld it up in place.
Old Oct 22, 2012 | 02:10 PM
ZzzZSlow's Avatar
So I'm going to throw a check engine light.. mm I see
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
