How do you know?
Old Oct 25, 2012 | 08:39 AM
Totalpckge1's Avatar
How do you know?
How do you know if you have bad strut mounts? I know this has been posted before but people tend to go way off topic and I didn't find a direct answer. Can someone please help me please.
Thank you
Old Oct 25, 2012 | 08:55 AM
blacksignature's Avatar
Usually when you turn the wheels back and forth fully you hear squeak and the popping. Have someone turn the wheel back and forth and watch the strut mount front under the hood. If they are bad you will see it.
Old Oct 25, 2012 | 09:04 AM
Thanks bro will do. Will I also hear clunking when I hit bumps on the road?
Old Oct 25, 2012 | 10:29 AM
rblower2012's Avatar
If your hearing a clunking when you hit bumps, and it squeaks and pops when you turn, you need strut mounts
Old Oct 25, 2012 | 10:42 AM
What are the best ones I can get?
Old Oct 25, 2012 | 11:14 AM
Probably oem. Check rock auto. If you buy cheap autozone ones they might pop like the old ones. Might as well knock the struts out while you got the spring off.
Old Oct 25, 2012 | 05:02 PM
How is the Moog brand?
Old Oct 26, 2012 | 07:05 AM
BigLou55's Avatar
http://forums.maxima.org/5th-generat...on-thread.html reading is fundamental
Old Oct 26, 2012 | 09:19 AM
RR5's Avatar
RR5
I've replaced my strut mounts, struts, tie rod ends at a friends house. Took the car to a shop to get the springs aligned with the mounts and still get all the noise (creaking and clunking .. metal on metal sounds) when the road is uneven.
Old Oct 26, 2012 | 02:02 PM
Originally Posted by rr5
i've replaced my strut mounts, struts, tie rod ends at a friends house. Took the car to a shop to get the springs aligned with the mounts and still get all the noise (creaking and clunking .. Metal on metal sounds) when the road is uneven.
wtf?
Old Oct 26, 2012 | 03:03 PM
Bro did you check the inner tire rod ends and the stabilizer bar links
Old Oct 26, 2012 | 09:49 PM
RR5's Avatar
RR5
Not yet but that might be a good idea. Forgot to add the sway bar links were replaced also. Used Moog where I could.
