Car alarm system does not activate...panic button works
Old Oct 25, 2012 | 08:53 AM
District's Avatar
Hey guys, my 01 maxima does not make the beeping boise when I lock the doors with the car keys....and the alarm system does not trigger when I touch the car or try anything with it.....yet the panic button works. Any ideas on what to do?
Old Oct 25, 2012 | 09:03 AM
Amerikaner83's Avatar
factory or aftermarket?
Factory doesn't go off when you try a door with it locked.
If aftermarket, check your wiring.
Old Oct 25, 2012 | 09:24 AM
Chuckles03SE's Avatar
Make sure all your doors are closed tight and that all the door closed switches in the jams aren't gunked up and actually pop in and out as they should.
Old Oct 25, 2012 | 09:27 AM
rebelhell's Avatar
^This. Also check the trunk and hood switches as it won't activate if it thinks any doors/hood is open. The beeping can be disabled I think so try setting the alarm with your windows rolled down. Then you can unlock and open a door...that should set it off.
Old Oct 25, 2012 | 09:42 AM
^ That definitely works. I did that at 7-11 one night about 3 days after I bought the car. Scared the poo outta me!
Old Oct 25, 2012 | 09:45 AM
DennisMik's Avatar
You didn't say specifically if the doors lock when you press the button on the key fob (remote). If they do, then the lights should flash when the doors lock. The beeping is a feature that you can turn on/off with the key fob. If the key fob is not an early production one, it has the beep on/off directions on the back of it.
Press both the lock and unlock buttons together for 2 or 3 seconds to toggle the beep on/off.
Old Oct 25, 2012 | 01:52 PM
^ This guy knows his stuff! I've had my '03 since 2006 and had no idea you could toggle the beep on/off. Man I love the random knowledge that the orgers have to pass along! Thanks Dennis! I guess I should read all the way through my Owner's Manual sometime soon...
Old Oct 26, 2012 | 10:48 AM
DennisMik's Avatar
Yeah, it can come in handy. That piece of information and a few dollars will get you a cold beer in many places.
Old Oct 27, 2012 | 09:37 AM
It could make it a hell of alot easier to sneak in after a night out with the fellas when the wife/girlfriend has gone to sleep as well!
Old Oct 30, 2012 | 09:58 AM
jeludev's Avatar
It would be cool to hear if the door locks react on the button? If they are not so there might be a couple of reasons. Someone's car parked nearby has broken alarm and its signals are interfering with yours, sometimes radio controlled door locks can interfere with car alarm frequencies. Or someone uses remote control jammer. You can read more here.
Old Oct 30, 2012 | 06:19 PM
MarkVD4's Avatar
Whats Up Guys i got a quick question. I noticed that one of my horns stoped working the low tone i believe so i replaced them with a set of air horns wired to the horn switch with a relay. Now i noticed that when i hit the panic theres no horn sound at all. Should there be something from the air horn? The lights and all blink but theres no sound. Didnt have a chance to really check the fuses due to the weather. Could this be a blown fuse or relay problem?
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
