Climate fan/defrost only start working when I hit hard bump
I changed resistor part under glovebox but did not fix.
Fan and defrost work but only on speed 1 (takes forever to heat car)
So it's not resistor. What else should I do /check?
Occasionally when I hit pothole everything starts working again.
2001 max SE 20th
Thx
2001 max SE 20th
Thx
You can pull the harness that plugs into the motor and hookup a voltmeter to the end. Check the voltage at the various speed setting to make sure there isn't a problem with the climate control box. If that tests fine, the next thing is to make sure the contacts on the blower are in good shape. It also wouldn't hurt to remove the blower, spin the blower wheel by hand to make sure it spins freely. If it doesn't, chances are the blower motor is going bad. While you have it out, you can look for evidence of the blower wheel making contact with anything as well.
S
S
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
