Shifting weird from 1st to 2nd (auto)
Old Nov 19, 2012 | 01:26 AM
akmaximafan's Avatar
Hey guys I was hoping to find some answers to my weird transmission issue.
I have a 2001 GLE V6 automatic. During a slow transition (say a slow speed take off) from 1st to second it's shifting hard into second gear after a sudden RPM spike during the shift from 1st to 2nd. Obviously this indicates a possible slip.
BUT! If I 'get on it' during my initial take off and climb the RPM's in the range of 1700-1850 before the transmission shift gears it shifts smooth as butter into 2nd gear.
I believe it to be a TCM/Silonoid issue and I was hoping to get some more feedback. You guys are great I just wanted to say I've found everyones opinion to be helpful.
Old Nov 19, 2012 | 12:46 PM
user name001's Avatar
Could be the TCM, I replied to your post in the other thread, im betting its your TPS. Read my post to you in the other thread..
Old Nov 22, 2012 | 08:23 AM
03blackSE's Avatar
Hard 1-2 shifts with light throttle is normal for auto Maxima's. Mine has been doing this since day 1.
Old Nov 22, 2012 | 09:50 AM
MONTE 01&97 SE's Avatar
Car to car basis, mine shifts smooth and fast no matter how I accellerate. Try resetting your ECU, which sets it back to its original state and it will shift better. If that doesn't work which it should, try the TPS calibration thing. 02+ can do the gas peddle thing, 01 and older can do the disconnect battery cable deal.
Old Nov 23, 2012 | 07:09 AM
Finchum's Avatar
mine shifts this way as well. Slight 1-2 hard shift during light throttle acceleration, but smooth if accelerating more than 30%.
I figured it was normal when the characteristics didn't change with complete oem fluid change out, adding an external oil cooler, and a touch of lucas trans slipstop.
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
BobTX10
Oct 7, 2015 08:43 AM
hayne
Oct 5, 2015 11:53 AM
