codr p0300 multiple random misfire
Old Nov 20, 2012 | 01:35 PM
originalhandy's Avatar
It showed cylinder 4 before so I changed all spark plugs, then tge ignition coil on 4 too.
it didnt fix it and now I get the above code.
where to start?
Old Nov 20, 2012 | 02:22 PM
foodmanry's Avatar
Da Roller Coaster!
where to start?
It could very well be another ignition coil. The FSM states to check the following:
-Faulty spark plugs (already changed)
-Faulty ignition coils
-Intake air leak
-Ignition coil harness open or short
-Clogged or faulty injectors
-Injector harness open or short
-Insufficient cylinder compression
-Incorrect fuel pressure
More than like it is another faulty coil. You can try checking some of the other non costly items such as the intake air leak, ignition coil or injector harness faults (multimeter and FSM). But, I'm betting it is another ignition coil.
Old Nov 20, 2012 | 02:26 PM
well **** lol. thansks for the info. I just saw I multiposted, can a mod merge or delete the other ?
Old Nov 20, 2012 | 02:35 PM
TunerMaxima3000's Avatar
Air filter and Vacuum leaks are the first and easiest checks.
P0300 is random misfire. This can be just one cylinder, intermittently.
OR it can be multiple cylinders intermittently.
Because it's intermittent, the computer can't tell which Cylinder is mis-firing specifically.
You need to check for stuff that would affect the entire system before you point fingers at individual things like a coil pack when you have this code.
jmlee44
Oct 2, 2022 02:13 PM
TKHanson
Nov 24, 2018 01:39 AM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
