Apexi Safc-ll
Old Nov 25, 2012 | 09:07 AM
maurice240sx's Avatar
Apexi Safc-ll
With the following mods is it worth it to get a Apexi Safc-ll? Cattman popcharger, Nwp 5 piece spacers, nwp block off plate, timing set to 17 degrees, cattman y-pipe, 3" testpipe, and Megan Racing 2.5" catback exhaust. Don't want to get headers at this time. Just want to gain the most power with what I got. Thanks
Old Nov 25, 2012 | 02:21 PM
Chris Gregg's Avatar
Get Off My Lawn
Short answer maybe. Medium answer, search....tons of threads outlining mods and what those who run air/fuel controllers have which required and AFC. Long answer.... you may see minimal gains, you are of course going to need a wideband. To maximize the value of getting an AFC, should look into a larger diameter MAF (LRMAF). You will see improved gains with 3" exhaust as well.
Old Nov 25, 2012 | 04:09 PM
036mtmax's Avatar
Your borderline there my friend. Usually with an intake, headers and all the other mods you have you will be a little on the rich side. You can do one two things to check your air fuel ratio. Install a wideband 02 and do a few test runs or throw it on your local Dyno and check your A/F's on there. AEM makes a nice wideband that you can datalog with for a descent price.
Old Nov 25, 2012 | 06:31 PM
Rods03Max619's Avatar
I think you will gain something, and why not use a 2.5 Testpipe to go with your 2.5 Exhaust, I got a 3'' TP also but got the 3'' Exhaust think it will flow more smoother if you had a 2.5 one, I should Dyno Tune soon but with work and **** looking at Jan. Feb. sometime.....
aw11power
Oct 10, 2021 04:57 AM
Maxima_Joe
Nov 25, 2015 08:19 AM
Slamrod
Sep 3, 2015 07:38 PM
samiam
Jul 18, 2001 02:34 PM
