NEED HELP!! EGR problem
Old Nov 27, 2012 | 07:42 PM
flyboy98's Avatar
I am in the process of reinstalling an intake manifold on a 2000 Max with a VQ30DE engine. But I have ran into a problem. I forgot if anything (such as hoses) attached to the EGR solenoid. I have attached a couple of pictures.
I need to try and get this vehicle back together in the next couple of days. I am going down for a serious surgery and will be down for 4 months.
Help!!
Attached Thumbnails NEED HELP!!  EGR problem-cimg0005.jpg   NEED HELP!!  EGR problem-cimg0007.jpg
Old Nov 28, 2012 | 08:07 AM
foodmanry's Avatar
Da Roller Coaster!
Help!!
I honestly can't tell. I looked at my engine bay and could see the EGR valve with hoses coming off it. It looks like those two ports should hook to something.
I reviewed the FSM and that was no help. If no one else chimes in I'll see if I can remove my intake to get a better look.
Do you have any other hoses in the area? The stock hosing is bent specifically to connect ports so it can be pretty easy to line up.
Old Nov 28, 2012 | 08:15 AM
user name001's Avatar
Yes there are lines that run to it. Your throttle body and IACV are out right now, if you looked at your IACV you should have to lines running off it from the underside that connect to those ports, then those two coolant lines you have label obv. Go to your IACV.
shilov
Feb 19, 2024 09:40 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
bumpypickle
Sep 19, 2015 01:07 AM
