Parking brake help
Old Jan 12, 2013 | 06:04 PM
vkcooke90's Avatar
Parking brake help
I have a '00 Maxima 5spd SE. My driveway is very steep and when i either back into my driveway or pull straight in I cant sit all the way at the top of the driveway with the parking brake set (even when pulling the e-brake ALL THE WAY up till it wont move) without the vehicle rolling back down. With my 2007 Taurus it doesnt matter if i pull in or back in I can set my vehicle with the e-brake only and it doesnt move. My question is not only why is this happening and if i need to adjust the e-brake do i need to take the center console out or can I do it without disassembling the console. Thanks.
Old Jan 12, 2013 | 06:15 PM
StevieB's Avatar
There's an adjustment nut(10mm) located at the base of the handbrake control which you should be able to access if you remove the handbrake trim. Try tightening it, but your problem may not be the cable adjustment as the handbrake mechanism on the rear calipers on our cars tends to deteriorate over time and not function effectively. Good luck
Old Jan 12, 2013 | 07:01 PM
vkcooke90's Avatar
The cover is removed because i can see the hole when i pull the e-brake, so all i need to do is to tighten that nut, I had the rear calipers replaced because of a no e-brake issue. So the calipers are good. Does the e-brake need to be engaged or disengaged while making the adjusment.
Old Jan 12, 2013 | 07:50 PM
cjandura's Avatar
Nope bro you have tje same issue as all of us either frozen rear calipers or siezed brake cables.suck it up and replace them all
Old Jan 12, 2013 | 09:24 PM
StevieB's Avatar
I usually end up with it partially engaged to allow access to the nut but whatever allows you to access and tighten it depending on the tool you use, short of full engagement. After you adjust it make sure it's fully disengaging when released. If that doesn't solve the issue, and assuming your calipers are good (I've had rebuilt calipers that were defective out of the box) then the issue will be the cables.
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
