Rusted Radiator Support
Old Jan 21, 2013 | 08:19 PM
rebelhell's Avatar
I am currently in the process of dropping my transmission to replace the clutch (slowly, it's cold). While under the car I noticed the radiator support has started to rust. I know this is typical and many of you have replaced them. My question is about trying to save it. It still seems early in the rusting phase. The steel is structurally sound (for now). Has anyone had any luck with rust converter and paint to prevent further deterioration?
Old Jan 21, 2013 | 08:33 PM
DrunkieTheBear's Avatar
Turbo'd Saab
POR15 is amazing stuff
Old Jan 21, 2013 | 08:41 PM
T_Behr904's Avatar
They rust from the inside-out. If you can see it on the outside, or bubbling, then it's probably too late to save.
Old Jan 22, 2013 | 08:38 AM
[s3]'s Avatar
Replace it now since you have parts off or do it again when it totally crumbles.
Old Jan 22, 2013 | 02:07 PM
rebelhell's Avatar
I looked into this stuff. Definitely seems worth a try.
I'll pull the radiator and have a look before I do anything. I have to drain it to replace the lower rad hose anyway.
Old Jan 22, 2013 | 03:25 PM
cjandura's Avatar
Eastwood.com has some nice restore products too.
Old Jan 22, 2013 | 10:34 PM
David3267's Avatar
REPLACE NOW or it will look like mine I have 151k on my clock check my thread
http://forums.maxima.org/5th-generat...e-maximas.html
Old Jan 23, 2013 | 07:31 AM
[s3]'s Avatar
Just FYI, paint and spray inhibitors are great but rust doesn't sleep until it's been totally sanded/grinded off, treated and sealed. You might be able to cover the surface rust but if it's anything deeper than the surface you are just delaying the inevitable.
If and when you do get the new OEM piece, paint it, rust proof it, rubberize it before you install it. Spray the insides as well.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
RealityCheck
Oct 2, 2015 06:34 PM
uttadms31
Sep 30, 2015 05:24 AM
