Rusted/Welded Radiator Support.
Old Jan 27, 2013 | 05:19 PM
TravisCadello's Avatar
Well I took pics to see what you guys think about this, Do you guys thinks its safe for a few more months or should i park it and not risk it. I dont have the Money to do the job quite yet & I don't want a cheap ebay one. cars from Louisiana but is now in Texas i pressure washed everything hoping to get SALT off the rusted spots but someone WELDED a plate across it, should i primer it at least with rust oleoum ? Im asking because i hear a poping noise and not sure if its a bad motor mount or the radiator support bout to let go and drop motor.
00 Maxima Se 5 speed.
http://i288.photobucket.com/albums/l...psc7560c01.jpg
http://i288.photobucket.com/albums/l...ps201c5505.jpg
http://i288.photobucket.com/albums/l...ps36ac0d74.jpg
http://i288.photobucket.com/albums/l...psf71c3a04.jpg
http://i288.photobucket.com/albums/l...psf7788e41.jpg
Old Jan 27, 2013 | 07:03 PM
spock's Avatar
Although it's pretty ugly, I would still drive it in it's current condition. You are still jscking it up @ the spot in question.
Old Jan 27, 2013 | 07:06 PM
Yea, Lol that wasnt too smart...I think im gonna sand it down and weld it a little better then primer it up and spray under coating on it. ill Have it replaced next month or two but i hear a popping and idk if its from that or not.
Old Jan 28, 2013 | 12:21 PM
DanNY's Avatar
Ad·min·is·tra·tor
IMO leave it or treat the rust. don't sand or grind at it...it'll just expose more metal and leads to more rusting..faster.
Old Jan 28, 2013 | 01:05 PM
how do i treat rust? just clean it up n primer it with rustoleum?
Old Jan 28, 2013 | 01:06 PM
cjandura's Avatar
Ill post how i fixed mine in the 4th gen only cost me $30 and will outlast the car!
Old Jan 28, 2013 | 01:36 PM
Kool....ill be waiting for this
Old Jan 28, 2013 | 03:47 PM
DjHackStyle's Avatar
Ill subscribe to this just to know what i should do for preventative maintenance, i never wanna have this problem.
Old Jan 29, 2013 | 04:07 AM
cjandura's Avatar
http://forums.maxima.org/8255684-post11.html
3- 1/4"x3"x36 flat steel stock
2- Grade 8.8 14mm Stainless Steel tall Nuts and Washers
1- Can expanding Foam
2- Cans 3m Undercoating(pep boys)
1- Can Eastwood Anti Rust(Eastwood.com)
1- 1lb pack of E7014 3/32" welding rods(just incase)
I totally boxed the lower section and welded in 'H' supports internally.this will outlast the car and its not going to rust and its solid!
Old Jan 29, 2013 | 06:22 AM
sontakke's Avatar
Can you expand on it? I would like to learn. I already paid to have this fixed but I am really curious as how you did it.
Old Feb 3, 2013 | 10:07 AM
So u weld the hell out of your and painted it basicly? if so ill do that instead of replacing entire radiator support.
Old Feb 3, 2013 | 12:12 PM
cjandura's Avatar
Its actually 24" section i replaced thats not pain either after all the weldind and drilling was done i rust proofed the inside then filled with expanding foam then coated the outside with rust proof and then coated it with like 5 coats of rubberized undercoating
Old Feb 4, 2013 | 11:26 AM
DanNY's Avatar
Ad·min·is·tra·tor
as long as the damage is not THAT bad you should be ok on the patch. if there's nothing there and the rust is growing (basically your x member is no longer connected) then you might want to have a new lower radiator support put in.
like cjandura when i do replace the lower support all welds are primed with well through primer and all the bare metal are primed and under coated.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
jchronis2552
Sep 23, 2015 04:57 PM
Hdnseek
Sep 9, 2015 05:55 AM
