5spd transmission help!!!
Old Mar 3, 2013 | 10:15 AM
VQtHuRtY's Avatar
A little bit of background. I have a boosted 3.0,5spd. I recently disintegrated my third gear, or that was the term used by my mechanic friend. I picked up recently-rebuilt transmission locally(from a 4th gen), and swapped them out myself. I noticed there's a small transmission leak coming from this little valve on top of the tranny. Not sure what it is. Can anyone chime in?
Old Mar 3, 2013 | 10:16 AM
VQtHuRtY's Avatar
For some reason pic keeps rotating upside down. Freaking iPad! Ain't nobody got time for that!
Old Mar 3, 2013 | 06:24 PM
fd3rew's Avatar
hard to tell from the pic but it looks like it is the vent for the tranny, you should have a hose attached to it that loops up and then back down again forming a "U" and then venting to atmosphere. The other possiblility is that the tranny fluid level is high and some of it is making its way to the vent tube.
Old Mar 3, 2013 | 08:14 PM
TunerMaxima3000's Avatar
That pic is kind of useless, can you get a better one with a arrow pointing to the leak
Old Mar 3, 2013 | 08:58 PM
noahrexion's Avatar
Originally Posted by fd3rew
hard to tell from the pic but it looks like it is the vent for the tranny, you should have a hose attached to it that loops up and then back down again forming a "u" and then venting to atmosphere. The other possiblility is that the tranny fluid level is high and some of it is making its way to the vent tube.
bam
Old Mar 3, 2013 | 11:27 PM
rebelhell's Avatar
This would be my guess. I'd show you what it looks like connected but my transmission is on the floor. That vent hose has been getting in my way for two days though so I thought I'd shoot you a picture. It just connects there and goes up about a foot and then curves back down. Held upright by a little tie connected to a bracket. It just vents to atmosphere.
Old Mar 4, 2013 | 01:24 PM
VQtHuRtY's Avatar
Makes sense cause when i filled up the tranny with gear oil it was jacked up extremely high. I was just concerned i wasnt getting that fluid where it needed to go, but it seems like its just supposed to vent. Thanks to all who gave input and those that took time to say dumb ish.
Old Mar 4, 2013 | 04:56 PM
ahhh fd3drew is right I think.
Your vent hose is below the transmission fluid level, causing it to leak.
You need to raise that 'ish up dude. If that's what it is, anyways.
Old Mar 4, 2013 | 06:58 PM
Nealoc187's Avatar
SLOW
he's right, it's the trans vent and it's supposed to have a hose on it. overfill could cause a little fluid to come out.
user 11122324
42
Jul 18, 2022 03:35 PM
ef9
Oct 4, 2015 08:43 AM
Pied
Sep 26, 2015 03:29 PM
