disabling auto headlamp
Old Jan 12, 2002 | 01:00 PM
JimmyH's Avatar
Does anyone know how to disable the automatic switch on the headlamps? I just put in HIDs and dont want them turning on, off, on when I turn the lights on.
Also, my new year's resolution is to use my turn signal, and the damn clicking is driving me crazy. Main reason why I never used to use it. Does any one know where the clicker is so I can clip the wires? And whether or not that will disable any other part of the turn signal system?
thanks
Old Jan 12, 2002 | 02:27 PM
2Maxed-out4u's Avatar
this may sound kind of stupid, but take the switch off of auto mode and put it to off. Whenever you want headlights on, cut them on. Promptly cut them off before you get out of car. simple solution to a simple problem.
Old Jan 12, 2002 | 02:31 PM
Greg's2kGLE's Avatar
Re: disabling auto headlamp
thanks
Don't cut any wires for the sound for the turn signal. If you can't hear it you might not know its on. Just turn up the music if you don't want to hear it. As 2Maxed-out4u, a simple solution to a simple problem
Old Jan 12, 2002 | 03:29 PM
ispeed's Avatar
part of the sound you are hearing is the relay ... if you cut a wire, to get of the sound, most likely your signals would not work.
Just turn up the radio, or don't use it. your choice.
Old Jan 12, 2002 | 06:41 PM
Maksim2000's Avatar
DO NOT JUST CUT THE FLASHER WIRES !!!!!
You would loose your turn signals totally.
On our cars the flasher is located on the right side of the fuse box under the driver's side bottom dash (it's black realy-is lookin thing). To get to it unscrew two bolts one on each side of the lower dash and then pull it out from center console->out. You might be able to wrap the flasher with some dynomat or something of that nature to make it quieter or if you are feeling really tricky you can relocate it under the hood somwhere it's just three wires to run it elsewhere.
Max
Old Jan 12, 2002 | 08:05 PM
TimW's Avatar
The silent but deadly Moderator
yes...
just wrap it with dynamat, its easy to reach.. my relay was squealing last month, had it replaced.
Old Jan 12, 2002 | 10:08 PM
jeffil's Avatar
I sometimes just leave my switch in the "parking light" position then
I can turn on the head lights if I wish. The parking lights will
go off automatically after you shut off the engine and open the door. If it's the middle of the day, you could turn the switch off without the "auto headlights" coming on.
Old Jan 12, 2002 | 10:16 PM
2001SE's Avatar
thanks
Ummmm....exactly why you never used the turn sginal? what are you some kind of a retard that can't hear a turn signal...lol, never bothered me before, never, unless its clickin too fast
Old Jan 13, 2002 | 08:08 PM
JimmyH's Avatar
so it seems the concensus is: I am not going to be able to disable the auto headlamps, and I can only mute the turn signal clicking.
And I am probably the only maxima owner hear who listens to AM talk radio? (If you are ever in Chicago in the early morning, check out Spike on 720, he is the man!)
Oh well.
Well, I have put in HID's (a really deep purple too) chromed the two fat crosses on the grill, and put projector fogs in in the last couple of weeks. So hopefully I can get some pictures up soon.
Jimmy
Old Jan 13, 2002 | 08:24 PM
costcowholesale's Avatar
Oh well.
Jimmy
AM radio, OMG. I only listen to it when theres a big snowstorm or something really bad & I tune it into the news channel.
Old Jan 13, 2002 | 08:59 PM
tomz17's Avatar
Ya... so that the clicking becomes permanent. Tinnitus blows.
Old Jan 13, 2002 | 11:20 PM
MaximaTrojan's Avatar
thanks
what kind of HID's did u get?
Old Jan 13, 2002 | 11:26 PM
Ludacris's Avatar
I listen to RadioDisney all the jammin hits on AM
Old Jan 14, 2002 | 03:44 PM
JimmyH's Avatar
Re: Re: disabling auto headlamp
http://store.yahoo.com/speedlights/hidkitwitnew.html
Old Jan 14, 2002 | 06:52 PM
zman187's Avatar
Dude they made the blinkers for a reason, use them. I can't stand when people don't use theirs, its not like you have to listen to them for hours on end, its like a max of 30 seconds, just use them.
Old Jan 15, 2002 | 11:42 AM
MyownNismo's Avatar
Future Camaro SS owner
Could you just find the auto wire in the switch with a logic probe (exp) you turn to auto that means the wire recieves 12v but also if in auto the headlight wire could also see 12v if not you could just cut the auto wire. But the easy way to do it is turn off when not using and at night just turn to auto that's what I do.
AaronL
Aug 8, 2020 10:31 AM
hayne
Oct 5, 2015 11:53 AM
Maximeltman
Sep 28, 2015 07:19 PM
dshinn
Sep 26, 2015 08:07 PM
