Eninge Ticking or tapping at idle Video included
Hello all,
Before anyone starts to flame me, I have done extensive amount of searching on here and google to isolate my problem. I was leaning towards a timing belt tensioner, until i noticed that its a a chain related sound. Its more of a tick tick tick sound comming from back of the enigne just below the intake manifold it seems. Some other people said that it could be injectors, knock sensor or even a crank sensor. I have pulled codes and there arent any. No CEL. Its pretty loud tick or tap if you will. Here is a video of the noise. Also I checked the oil, drove the car and let it sit on a level gound for ahout an hour and checked. Its right in the middle between H and L. Other then the noise, the car drives perfectly fine, but the noise is driving me nuts. If any of you veterns can chime in I would really appreciate it. Where should I start? Thank you
http://www.youtube.com/watch?v=_11Ky...ature=youtu.be
Check your oil pressure, my oil pump failed and it was putting out just enough at idle to keep the light off, but not enough to properly lube the engine. When it was above 2k the oil pressure was adequate. Definitely not injectors, you can hear them tapping in the background of that knock.
alright, thanks g.man06! I will start there. Did your car kinda sounded like mine?
BTW do you think that there is a possibilty that it could be the timing belt tensioner?
I don't really notice the difference, but when I did some poking around, my sounds a lot similar to people having stuck lifters...
i tried the seafoam method in the intake and in the crankcase. The noise still remains...
what do you think it is pj? Its driving me nutzzzzzzzzzzzzzzzzzz
Update,
I took the car to a muffler shop. They raised the car in the air used a stethoscope to find and leaks... There were no leaks. However I do have an engine light on. I will be going to parts store to find out why.
Update,
aviation005,
the sound is like a valve tick, but i am not sure. The sound is for sure just below the intake manifold or at it. I am doing coil pack research as I type this....
Steezemuffin686,
When the rpms or up so does the noise. It follows the rpm. But its hard to hear after 2500rpm. When I am just driving through resi streets, you can hear it. Or driving against a wall or rail.
Also,
Can a bad knock sensor cause my noise?
Steezemuffin686,
Also,
doesnt sound like a sensor or anything sensor related to me or an exhaust leak, definitely sounded mechanical, like lifter/rod/piston/etc. If you are going to take it somewhere next, I suggest an actual repair shop
It really sounds like its comming from the back of the engine towards the firewall. Just below the intake manifold. The funny thing is, it doesn't burn any oil and the car drives fine. Just the damn noise. I have added marvel mystery oil and have been running for about 400 miles. Nothing has changed. I also did the seafoam thing in the intake and a lot of white smoke came out but that was about it... I think I might try to put in some seafoam in the gas tank next... Really out of options. I really don't want to spend money into repair it at a shop. The car has over 150k miles on it and I paid $3300. Other then the noise, the car drives perfect.
Any update on this?
Sounds identical to the same problem I'm faced with on my 02' Maxima... Gonna try changing the spark plugs, but I'm betting this isn't gonna help. Try the least expensive fixes first.
Btw, does it sound similar to this? Sorry for the airplane in the background
We had a 2003 came in at our shop with only 112k miles with that same noise. Customer didn't change the oil in 50k miles! He didn't want to spend money on the car, only thing he paid for was an oil change. A year later he called back quoting a motor job..
Car has been maintenanced almost perfectly... They did the front plugs but not the back lol. Gonna change them. Idle is a little off. Even have all the records from the previous owner. Had one mechanic say the timing chain but the noise is more towards the rear. I'll reply back with the result
As I suspected after hearing the car, the ticking is from the cam lobe slapping the bucket due to excessive lash. This car was either neglected at an oil change interval and/or the oil port that feeds the #5 exhaust buckets is clogged and has caused excessive wear. More specifically #5eb (the very last exhaust bucket on bank#1)
VQ35 buckets/lifters are solid (once piece) and can't be adjusted. They, and probably the cams as well, have to be replaced which is a VERY labor intensive and expensive process.
VQ30 engines have replaceable lash pads but they require just as much time in labor to replace.
I think a bad ECU helped contributed that problem over a long period of time..
AaronL
Aug 8, 2020 10:31 AM
Unclejunebug
Apr 2, 2016 05:42 AM
