Intermittent engine stutter
Old Mar 28, 2013 | 01:28 PM
paradiddle's Avatar
Intermittent engine stutter at idle - not quite a sputter or misfire. No CEL. Runs ok otherwise. recent MAF problems but fixed that. replaced plugs.
10/01 ( 2002 ) 3.5l with 175K miles and its an oil burner. 1 qt every 1000.
Old Mar 28, 2013 | 01:37 PM
foodmanry's Avatar
Da Roller Coaster!
You can have a bad ignition coil or coils and NOT have a code thrown. Your symptoms line up with an intermittent misfire of one ignition coil.
I had the same problem and it finally threw the general misfire code after the coil got pretty bad with the intermittent misfire. I bought one new front and one new rear coil. Changed them one at a time until I found the bad coil.
Go with OEM ignition coils as aftermarket coils are hit and miss in terms of quality; no pun intended.
Old May 14, 2013 | 09:15 PM
paradiddle's Avatar
fixed
new bosch platinum plugs from walmart fixed it !!
AaronL
Nov 15, 2020 11:52 AM
mikeg75
Nov 30, 2015 05:12 PM
RWCreative
Sep 21, 2015 11:01 AM
lrb6805
Sep 17, 2015 04:49 PM
johnaschon
Sep 14, 2015 04:29 PM
