I changed out the bulbs for leds in my cluster today, that is an easy mod to do!
3 Attachment(s)
gave myself a key that can go on a keyring
Attachment 21768 put the rack on Attachment 21769 couldn't decide if i wanted the fairing or not- was having trouble getting it to sit flat and got tired of messing with it. took it off, threw the bike rack up and this is how it will sit until i decide if the added noise truly bothers me Attachment 21770 |
My babe is in my friend's shop garage getting brakes job done and $#&!!*$* Catalytic Converter replacement, and once she all fixed up I"m gonna lowered her some more! :D
3 Attachment(s)
Did an at home alignment.
Turned out real good. It's still acouple mm to the left but I'm going to tinker with it some more tomorrow. Way better then how it was @ 10 o'clock.. Now it's at 11:58 :D Did it on the floor using this guy's suggestion. https://www.youtube.com/watch?v=OzN0Z2HupcM Attachment 21741 Attachment 21742 Got a new phone and tried out an effect just for fun :p Attachment 21743 |
Originally Posted by Donkeypunch
(Post 8972608)
Home made racing slicks FTW?
That's what a 300 shot of nawz does boys :naughty:
....and bad toe settings. |
p0102 and p1102....limped to autozone for those codes.
Anyway I got the new MAF and a filter while I was at it today. Installed and did the pedal dance to reset the ECU. I didnt disconnect the battery, oops. All seems to be fine now. Damn that MAF was expensive! |
Changed the in cabin air filter.
Replaced main cat with a gutted cat. Not very exciting but kind of a first step to replacing the precats.
Installed the BRM 3" exhaust and replaced my front valve cover gasket
Installed led's in the car--total spent $14.00.
Installed speedometer led backlight--total spent $17.00. Installed new ABS sensor. And a wash/wax |
2 Attachment(s)
5 Attachment(s)
I gutted the precat's
before gutted and off the car Attachment 6244 Front precat before being gutted- look at that crap clogging it up Attachment 6245 Front precat after being gutted Attachment 6246 Rear precat before being gutted- metal type of material Attachment 6247 Rear Precat Gutted- nice and hollow now Attachment 6248 I pressed in my ES motor mounts. i changed My water pump and thermostat and my Timing Chain Tensioner all with Genuine Nissan Parts. <----- i jumped timing doing the water pump and had to take off the timing cover to set the timing marks correctly only to put it all back together and still have the timing off 1 tooth. now i have to redo that crap again this week. Grrrrrrr I went off topic a little bit, But the last of it is replaced the Radiator with a $61 koyo from rockauto. replaced both belts. changed all spark plugs with NGK/Nissan Single tip Platinum Spark Plugs. i had a hookup and got them for $8 bucks each at Star Nissan rather then the $13 they had them listed for. cleaned my throttle body replaced the PCV. all work was done with the Engine still in the car btw. |
The front cat was well clogged!
need to do mine here soon at almost 200,000 I bet they're clogged. |
Hey are these strut braces any good? Reason I ask is because they're so cheap. I'm just getting the front done.
http://www.streetbeatcustoms.com/Meg...NM00FU/773616/ |
I had one. They are cheap but fairly solid once set up. I had to remove it though once I put on my NWP spacers. It will rub on the IM and I never got around to grinding so it would fit.
Ahh okay, thanks mate. I'll go ahead and get these.
Took a hard drive down some windy roads thru the woods few nights ago with a buddy, these roads were in bad shape with bumps all over the place.
Long story short, this drive was bumpy enough and fast enough to blow my radiator. Opened hood next day (which was yesterday) to find a bunch of coolant spray. Ordered new radiator from 1800radiator and got it within a few hours, replaced, good to go now. :nod: |
Changed the oil and oil filter. She seems happy! :D
On the gen 5.5
- Changed wiper blades... Old ones were STUCK - Ordered oil catch can for it - Front lip getting repainted - Front grill getting repainted On the gen 4 - Took it to work - Quick wash |
Originally Posted by george__
(Post 8974980)
On the gen 5.5
- Changed wiper blades... Old ones were STUCK - Ordered oil catch can for it - Front lip getting repainted - Front grill getting repainted On the gen 4 - Took it to work - Quick wash :hide: |
7 Attachment(s)
Get my car washed and waxed over the weekend....
Attachment 21529 Attachment 21530 Put on new OEM wheels from 2014 Nissan Tiida turbo Attachment 21531 Installed A33 Cefiro rear seat with headrests Attachment 21532 The best part of the Cefiro rear seat is that it came with center cup holder and small storage compartment: Attachment 21533 Attachment 21534 Attachment 21535 |
Wow, like that rear seat!!
This past weekend I repainted my grill. Changed the shell from dark gray to silver in order to match the body color. http://i1174.photobucket.com/albums/...ps6acqifh7.jpg |
Pressure washed the interior of the car.. got tired of spending money on products that wont clean fabric. Spent $6 and the interior and now it looks better than before.
Originally Posted by Maverick4189
(Post 8962137)
Thanks |
That looks like charcoal gray color ^^^^^^^
Originally Posted by zgrm100
(Post 8976292)
Hey, what color is your Maxima? Is this a stock paint color? Or did you re-paint it? Thanks |
Today i plasti-dipped my recently bought (used) Racingline FSTB...and installed it on!
Front end seems a tad more planted on take off/bends. I have way to many PENDING projects tho. |
Used CarGuage Pro to adjust my idle RPM +100 to 800RPM instead of the stock 700. Feels much smoother that way at idle, and sounds so much better at idle and on decelerations.
CarGuage Pro is an awesome little app for what it's worth. Checked my timing with it, and it was on point at +2. Anyone need timing advance? I'll do it free for any (no ricers) Max in my area. Doing it on a buddys 01 GLE today and then another 03 Max tomorrow. :naughty: |
I'm new.
2 Attachment(s)
I discovered what was making my car sound so good. I call it Natures Rumble.
Attachment 6284 I know this isn't the place but since it's my first post I'll fire some details out. '00 GLE, stock, in desperate need of some rims... Fuel economy is roughly 500 or less km's/ tank? It has been running regular all of its life, will be trying premium soon! Attachment 6285 |
5 Attachment(s)
I assumed power line was leaking.
But it was bone dry. :) So moved on to doing arm. Attachment 21379 Bushing was trashed. It pulled to the right when I gave it some gas. Attachment 21380 Attachment 21381 I may have over tq the ball joint since pin isn't even close to the nut. Attachment 21382 Need another alignment. New bushing put my wheel at 1:00 ! Feels good though steering is solid now. Attachment 21383 |
Failed the emissions test:rolleyes: evap codes
Hit a curb hard. Ran off tge road around a curve:/
New passenger CV axle and axle seal
Drilled 4 inch Holes on Filter housing instead of using hangers to to GAB mob. Filed edged as smooth as possible (mehh). Enjoyed a nice run and felt the VQ wake up. Best FREE mod in my opinion.
Sitting to the side is all components i need for a sri minus the "right" maf adapter (one i have isnt gonna work)..that will be phase 2 of intake mods. It what im going to do in a few days im most excited about--NWP block off plate :) install |
1 Attachment(s)
Wrapped my dash in carbon fiber vinyl that I got off of eBay for way cheap, sorry for the poor quality photo but you get the idea Attachment 21260
2 Attachment(s)
Detailed my engine bay. I bought it a few days ago and it was in need of a good cleaning. Not bad for 15 minutes of work.
Before: Attachment 21258 After: Attachment 21259 |
Nice Job! wanna do mine now?
Originally Posted by DjSinikal
(Post 8979288)
Before: http://i169.photobucket.com/albums/u...sc5e9b3f5.jpeg After: http://i169.photobucket.com/albums/u...sa497ad06.jpeg |
© 2024 MH Sub I, LLC dba Internet Brands
