Low Idle issues after alternator replacement
Old Jun 6, 2013 | 09:50 AM
midwboss's Avatar
Hi Im new to the forum and just picked up a 2003 Nissan Maxima 6spd . Two days after I purchased it the alternator went out. I replaced the Alternator with a new one went for a test and now once the car is warm it stalls at idle or when i release the clutch and allow the rpms to drop. I tried the relearn process and got blinking SES light and seemed to be done correct but still having the idle issues. Before changing the alternator this issue was not present it drove like a champ. Any Ideas on where to go next with this?
I have read alot about this on the forum and done see why I would need to clean the throttle body etc etc if it was running cherry before changing the alternator so im at a loss please help.
Old Jun 6, 2013 | 11:00 AM
VQP0WER's Avatar
First two things that come to mind:
1. Bad grounding connection
2. Belt slipping
It's also not unheardof for you to get a bad alternator from Auto Zone type stores.
Old Jun 6, 2013 | 11:42 AM
midwboss's Avatar
2. Belt slipping
Haha how did you know I got it from the zone . Checked all my grounds but maybe a bad alternator but its putting out correct volts. I have never seen a alternator cause stalling issues but its possible can you explain this theory a bit further
Old Jun 6, 2013 | 02:46 PM
VQP0WER's Avatar
Lack of voltage will shut the car off.......You can't just take a voltmeter to the alternator as that would give you the correct voltage, but when you apply a load to the car it will drop.
Old Jun 7, 2013 | 09:57 AM
midwboss's Avatar
I tested the charging system with a midtronics battery tester and everything showed good. and yes the tester applies a load.
Old Jun 7, 2013 | 03:33 PM
01maxium's Avatar
Try cleaning the MAF, there is a thread about that somewhere on here and see if that fix the problem. I don't think it could be the alternator if you did a load test on it but I could be wrong.
Old Jun 9, 2013 | 02:14 PM
victor02max6speed's Avatar
Its ur maf sensor believe it or not I had same issue I took i t to dealer dey replaced my throttle body and I changed sparkpplugs long story short maf is da culprit find another guy wiyh da same year maxima and try his just make sure not to touch his maf or mess it up and u should b good
Old Jun 10, 2013 | 07:35 AM
midwboss's Avatar
Ill give that a shot and report back
PH98I30
19
Jun 13, 2016 02:38 PM
Balkins
Feb 1, 2016 12:45 AM
Finkle
Sep 27, 2015 09:53 PM
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
