The art of shifting
Re: VERY Interesting!
Originally posted by IceY2K1
I gave it a few tries and double clutching works VERY nicely on my car. My car has REFUSED to downshift into gears since new. Usually I'm only able to downshift into 2nd below 15mph and 1st only at 2-3mph, so I just leave it in a higher gear and bog the engine. Just pushing in the clutch twice before switching gears works most of the time.
Recently I've added a SMC STS which made it all a little worse, but the shorter throws are fun. On my way to work I fly off of a 50-60mph straight away, brake like crazy, then turn onto a lane that banks right/left/right/straight. Anyways, before the STS I could sometimes "blip" the throttle drop into second and take the "rally course" at about 25-35mph. After the STS I couldn't "blip" the throttle and drop into 2nd, until this moring. I was going to revert back to my stock shifter, but if I can get the double clutching down I may keep it.
I haven't tried it yet, but the 5th to 3rd shift is what I really need to practice. I hate the feel of the tranny when I clutch, floor the gas, shift to third, and dump the clutch. The shifter/tranny/car buck.
THANKS!
THANKS!
In my 5spd, I hit clutch, blip the throttle to raise rpms about 500-700 and then shift and release clutch. When done at the proper rpms it is seamless.
As for your 5th to 3rd shift, you simply don't need to floor the gas, you just need to raise rpms around 1000-1400 above rpms in 5th. I've developed my blip so it equals about 500-700 rpms and when I do a single gear downshift i blip once, when I go from 5th to 3rd, I blip twice as long.
Originally posted by Norm Peterson
(Sigh) That's me and several sets of synchros in unison.
Whatever . . .
Whatever . . .
I "think" I am double clutching but might be missing the double part. To do it correctly you:
1) Push in clutch
2) Slide to Neutral
3) Release clutch
4) Blip throttle
5) Push clutch
6) Slide into desired gear
Right? What would be the difference(technically internal to the clutch and gbox) if you skipped step 3 and 5. As I have found (after reading and analysising my shifting yesterday) what I am doing.
You are double clutching.
But you're right, according to your numbers here is the order for "better double clutching":
1) 6) 4)
it should be called "single clutching"
no need to waste time with the clutch twice and neutral.
this way is twice as fast no matter what anyone says. not just for downshifting to slowdown, but also on a highway race (5th to 3rd). it doesn't hurt anything except for all those people's feelings you hurt out shifting them in a race.
1) 6) 4)
1) 6) 4)
1) 6) 4)
use the brakes to slow down - that's what they are for.
Unrelated? Not really. Think about it.
Norm
Norm
Originally posted by Colonel
Norm,
1) Push in clutch
2) Slide to Neutral
3) Release clutch
4) Blip throttle
5) Push clutch
Norm,
1) Push in clutch
2) Slide to Neutral
3) Release clutch
4) Blip throttle
5) Push clutch
The 'double' part refers to the two distinct clutch disengage/release cycles that take place.
In actuality, and as you're probably already aware, there's quite a bit of overlap among those 6 discrete steps (making the process sound and write clumsier and slower than it really is). The difference to the tranny internals is lower demands on the synchros due to matching the revs of the clutch disc and tranny input shaft. Single clutching won't rev-match those components.
Norm
I will concede that double clutching is nicer to the tranny, but hey, I'm single clutching. My tranny has lasted 120k miles so far. It's too much of a waste of time in normal driving, less spontaneous. I feel only a professional racer should be concerned with it.
DW
DW
Originally posted by Paul D.
. . . Using the 'heel n toe' method doesn't suddenly mean double clutching makes sense.
DW - In addition to professional (or amateur, for that matter) racers, anybody who downshifts such that the revs in the lower gear are more than, say, 1000 rpm above the rpm's in the gear shifted from should seriously consider it. At that point the driving is becoming less like street and more like track.
Norm
Ok. So double clutching will spare the tranny. After reading six pages of replies this is clear
. However, I don't have a clear picture of how this works technically. I guess with time and taking tranny-101 will help me better understand.
Along the lines of sparing the tranny I have a question. When waiting at the red light which of the following will wear out the tranny if at all:
* Keeping the clutch all the way in while in neutral
* Keeping the clutch all the way in while in gear (normally 1st gear)
I've been told that wear occurs only when engaging/disengaging the clutch but not when it's all the way in regardless if it's in neutral or gear.
I humbly ask for the Forums wisdom
. However, I don't have a clear picture of how this works technically. I guess with time and taking tranny-101 will help me better understand. Along the lines of sparing the tranny I have a question. When waiting at the red light which of the following will wear out the tranny if at all:
Originally posted by bramirez
. . . Along the lines of sparing the tranny I have a question. When waiting at the red light which of the following will wear out the tranny if at all:
I humbly ask for the Forums widsom
So, tranny in neutral with clutch out. Exceptions to this exist, such as where the potential for needing to move suddenly to avoid being hit by another vehicle obviously must take priority.
Norm
Sure it does, at least given a little thought to the circumstances and the physics of it. H&T is a road-race technique that there's little need for in normal (read legal) street driving, and as you approach a corner that implies much higher rpm's than normally encountered while driving on the street. The product of clutch disc momentum times rpm error is larger, which in turn becomes greater synchro demand and hence wear. Etc.
Norm
Norm
Unfortunately, I've found it too difficult to heel-toe on the stock pedals. So, I alternate braking with blipping the throttle for downshift and then braking again (an imperfect solution to be remedied by some pedals soon).
Double clutching in circumstances where one needs to heel-toe but can't *really* makes things more difficult.
But alas, you will have the least amount of wear on your synchros!
Norm
Norm
"anybody who downshifts such that the revs in the lower gear are more than, say, 1000 rpm above the rpm's in the gear shifted from should seriously consider it" Give me a break. Like I mentioned earlier I did a 6-1 shift last night at 65 mph and it was no big deal. If the syncros were being excessively overloaded by such an act I know I'd be able to feel it through the shifter, and if they were REALLY being overloaded the transmission wouldn't even have gone into 1st.
I've had enough transmissions apart in my lifetime to know that they're a lot tougher than what you're saying is going to lead people to believe.
Originally posted by Max_Gator
. . . Unfortunately, I've found it too difficult to heel-toe on the stock pedals. So, I alternate braking with blipping the throttle for downshift and then braking again (an imperfect solution to be remedied by some pedals soon). . .
I'd probably do a pedals mod myself, but I think my wife would object more strenuously than I'd care to endure.
Norm
You, too? (Same work-around here)
Norm
Norm
But, I guess she might step on the wrong pedal. Hmmmm.....
Otherwise she doesn't mind the mods like y-pipe/intake/pulley/ftsb and $200 tires. It only means that she spends more money on the house! LOL.
Do you actually double-clutch in that situation, though?
Paul (and to whom it may concern) – Sorry I sound a little strident on this topic. What mystifies me the most is the apparent refusal-to-learn-how / refusal-to-do / why-should-I-even-bother attitude that seems to be present. It just isn't that hard to do. Now, I'm sure that when I was 18 or 20 or so I didn't double-clutch my downshifts either, but that was because nobody ever mentioned it unless/until you got tuned in to sports cars.
I'm a structural engineer by education and by profession, with some experience in fatigue-related component life. I'd also have to rate myself as an 'advanced driveway mechanic' and, yes, I've rebuilt transmissions. Even Maxima transaxles.
FWIW, synchros aren't big beefy parts like final drive gears nor are they made of anything as durable as hardened steel. They're fairly small, relatively soft and work by acting as cone brakes.
I hope I haven't given the impression that just a few single-clutch shifts, regardless of rpm difference, will result in immediate synchro failure. Or even die after a few power shifts. That's not the case. It's the accumulated damage over time, heavy damage from each of a few high load cycles being as bad as very light damage from each of a large number of cycles. It's not linear.
I can't put any numbers on anybody's specific tranny life, but one general yardstick of estimated fatigue life is expressed as a number of cycles and is related to the inverse 5th power of the stress in the parts. Synchro dimensional wear is probably not that bad, so doubling the demand on the synchro every time will probably not wear it out 32 times as fast. But a 50% increase in stress done all the time suggests (1/1.5)^5 or 13.2% of original life span, doubling the stress drops that to 3.1% of original life span. If the relation between stress and lifespan was half (or more) of life for a doubled load I might think differently. Again, FWIW.
Some more FWIW: From some Chrysler publication many years ago I remember that their then-new 4-speed manual tranny was considered stronger than most, and was tested without synchro failure over 75 power shifts. Since that was the only data point published, I have to wonder about their actual condition. Hmmmm.
Norm
Norm
Norm
Norm
Funny thing is that "when I was 18 or 20" I not only knew about double clutching I was doing it all the time, but it sure had nothing to do with "sports cars", I was driving a 10 wheel tandem dump truck with two transmissions and had to be double clutching on the up-shifts as well as the down-shifts.
Figures that Chrysler would think 75 power-shifts without a failure is a good thing. I sure hope Nissan has higher standards than that because I did by first full throttle power shift when the car had less than 300 miles on it. I'm sure over the next few years I'm VERY likely to accumulate more than 75 such shifts and I sure don't expect the syncros to fail as a result.
I took a new GSXR-1100 with N2O activation at full throttle, went out and power-shifted that puppy with no problems. Man I probably put more than 75 power shifts on that bike the first day I had it at the track.
Well, the only time my wife drives my car is when I have to take hers in for service!
Norm
For what it's worth Norm
I thank you for all the information you supplied. I have been practicing the double clutch more often, and no I have not seen The Fast and the Furious. If I can save some tranny life after numerous dumps from fifth to third I gotta.
In single cluthing mode I
a) Push the clutch
b)downshift from 3 to 2
c) blip the throttle so i wind up at an engine speed higher than my previous gear
d) let out the clutch
Using this method, when the cluth engages, engine and tranny is spinning, more or less at the same speed. Therefore I would think that the single clutch method would also save the synchros. No?
How would double clutching be better for the synchros than what I just described above?
DW
a) Push the clutch
DW
Norm
Norm
a) Push the clutch
a) Push the clutch
I'm not disagreeing with the value of a single-clutch-with-a-blip. I will freely agree that blipping as you single-clutch on a downshift is much better than doing nothing. And I'll even concede that the single-clutch-with-blip method represents a bigger reduction in wear over the no-blip than a double-clutch does over the single-clutch-with-blip, since the larger amount of potentially "wrong-speed" mass is in the flywheel, pressure plate, and crank, i.e. on the upstream side.
Maybe this whole thing is a function of mind-set, similar to not wanting to settle for a lower score on an exam when you could have pulled a 98, or of not being satisfied with a 15.9 et when quicker was within easy reach.
Norm
This has been a very interesting thread. We may not double shift because we are lazy but I think we understand the advantage and the reason for doing it.
Threads like this are the reason that I'm still a member of this forum. It is very rare on here anymore that a thread doesn't degenerate into a "post *****" or smiley contest.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
