Is this tire trash?
Old Jun 13, 2013 | 11:34 PM
Genes1s's Avatar
Is this tire trash?
I bought a set of 350Z 17" staggered wheels with 9/32" tire thread left all around for $300 locally. Ties are Hankook Ventus V4ES 225/50/17 fronts and 235/50/17 rears. Didn't look at them very carefully till I got home when I found out one of the front tires has deep cut in which appeared to be gouges from the fender cutting into the tire. The other 3 were all in really good shape with a slight fender rubbing marks around outer threads. I was mad at myself for not catching this. I guess you never deal in a hurry.
The gouge is pretty deep in one section almost measured 6/32nd from the top of the thread. I think this is trash, but maybe not?
Old Jun 14, 2013 | 07:14 AM
TallTom's Avatar
As long as the sidewall isn't damaged, I think it would be ok to drive on them. The base rubber in the channels looks like it wasn't touched.
Old Jun 14, 2013 | 07:23 AM
Chris Gregg's Avatar
Get Off My Lawn
Agreed, doesn't look even as deep as the factory channels. Even though your measurement indicates it is slightly deeper, it looks like it may be because the outer tread is more worn. I'd run them.
Old Jun 14, 2013 | 07:47 AM
Nealoc187's Avatar
SLOW
if it doesn't go deeper than the tread molded in to the tire itself then it's fine. looks ok to me.
Old Jun 14, 2013 | 08:20 AM
dwapenyi's Avatar
Funny how the gouge almost enhances the uni-directional pattern in the tire, like it was made that way.
I'd run them too.
Old Jun 14, 2013 | 09:21 AM
m21bmr's Avatar
I agree with the sentiment of everyone else. I don't think the gouge compromises the integrity of the tire at all. I'd use it.
I'm not saying this is an issue, but there may be enough rubber gone in that one section that it will create a minor imbalance in the tire. If you feel any vibration from that wheel once mounted, having that one wheel rebalanced should account for it. My gut says there isn't enough material missing that you'll notice.
Old Jun 14, 2013 | 09:30 AM
Rods03Max619's Avatar
Looks cool to me I wojld roll em also like everyone else has said, and would be worried if the sidewalls were messed up but in this case its not, and 300 good deal tires look Damn near new....
Old Jun 14, 2013 | 09:41 AM
Genes1s's Avatar
I'd run them too.
I thought the same way too at glance and not untill I looked at the other tires that I realized that was not the case.
Old Jun 14, 2013 | 11:04 AM
MrEous's Avatar
^ Jeff™
Might make a noise or vibration (as said above) but I'd run it too
Old Jun 14, 2013 | 11:22 AM
Gemner's Avatar
I doubt its from rubbing on the fender since it goes further into the tire as it goes around. Fender rub causes a line that goes in a perfect circle around the tire. I have no idea what might cause that though, seems like the guy probably got a good deal on a tire that got screwed up in the mold
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
