Please Help Me Identify this Part ...
Old Jul 9, 2013 | 05:35 PM
Noela's Avatar
Hello,
My mechanic informed me that I need to replace my "Coolant Assembly Line" because my antifreeze is leaking through a short metal piece at located at the bottom of the car, near the front right tire. He is unable to give me the specific name for the part, but did indicate that it is part of the "coolant assembly line"
He also indicated that the metal piece is connected to a hose that runs/feeds into the engine - attached is a picture showing the hose (arrowed).
Kindly let me know if you have any idea what this hose is, and whether there are other (better) aftermarket replacement parts...
cheers, Noela
Old Jul 9, 2013 | 05:58 PM
Gemner's Avatar
check courtesyparts if you need the "exact" name for the part
Old Jul 9, 2013 | 06:22 PM
Noela's Avatar
thanks - I tried - I have copies of the FSM too - but I am not sure where to look....
Tried Heating and Cooling sections, but not sure .... so let me know if there are specific areas to check.
thanks - Noela
Old Jul 9, 2013 | 06:39 PM
cjandura's Avatar
The picture is your theromastat housing and what is leaking near your wheel is the oil cooler line
http://www.courtesyparts.com/maxima-...1981_1986.html
Sent from my iPhone using MaximaOrg
Old Jul 9, 2013 | 06:49 PM
rebelhell's Avatar
Spot on cjandura. Oil cooler line. The flexible hose connects to a metal pipe. Was rusted through and leaking on my car. Should be easy to replace yourself.
Old Jul 9, 2013 | 07:22 PM
cjandura's Avatar
Man if you even look at that metal line where it attaches to the a/c will leak if you look at it to hard
Old Jul 10, 2013 | 06:50 AM
Noela's Avatar
Thanks for all your comments ....
Man..... is that part really that prone to breakage / leakage ?
Old Jul 10, 2013 | 06:52 AM
NmexMAX's Avatar
dot dot dot ...
Mine's been fine. 130k.
Old Jul 10, 2013 | 07:50 AM
cjandura's Avatar
But you live in the dry azz desert only thing you need to worry about is a alien abduction and probing!
Old Jul 10, 2013 | 08:01 AM
rebelhell's Avatar
Bit you live in the dry azz desert only thing you need to worry about is a alien abduction and probing!
Really? Abduction AND probing? I need to move out West, where do I sign up?
Old Jul 10, 2013 | 08:10 AM
NmexMAX's Avatar
dot dot dot ...
This is true. The Pathfinder came from VA, and Jesus. Couple that with the fact that the Pathy is an 08 and the Maxi is an 03.
Old Jul 10, 2013 | 08:14 AM
rebelhell's Avatar
Yup, that salty sea breeze I love so much does NASTY things to steel. Nissan can't be blamed for that. Might as well dip your car in acid. Of course salty roads in the winter where I am now isn't any better.
Old Jul 10, 2013 | 08:23 AM
NmexMAX's Avatar
dot dot dot ...
Yeah, I have small remnants on the Maxima from the road salt, but nothing compared to the Pathy.
Old Jul 10, 2013 | 08:37 AM
Gemner's Avatar
its the salty roads, not the salty breeze. My maxima has been within 20 miles of the coast for probably 99% of its life and theres no rust to be found. If I were to park my car ON the beach that might be different, but having been on the east coast many times I can tell you there is a lot more sea breeze here, and infinitely less salt on the roads in the winter
Old Jul 10, 2013 | 09:13 AM
cjandura's Avatar
Oh if you looking for abduction and probing just move next to Crusher!
Old Jul 10, 2013 | 09:40 AM
tosheto's Avatar
I like this thread. I like salt too and pepper, but just a little for flavor.
Old Jul 10, 2013 | 09:47 AM
rebelhell's Avatar
Does he have his own alien spaceship? I only give it up to guys with their own alien spaceship.
Old Jul 10, 2013 | 09:59 AM
NmexMAX's Avatar
dot dot dot ...
They use sand here, the red stuff, and that new liquid de-icer. Salt is used very little. Although my car looks like it was salt blasted after a nice winter drive.
Old Jul 10, 2013 | 10:11 AM
Prophecy99's Avatar
http://forums.maxima.org/5th-generat...ain-cover.html
http://www.courtesyparts.com/21302mb-pipe-assy-water-maxima-a33b-2000-2003-p-45108.html
Old Jul 10, 2013 | 11:03 AM
cjandura's Avatar
Yes! His Mothership is bult out of a collection of 4th gens and I30's and a few thousand left over failed turbo parts......
Think TV show from the 80's called Salvage.
Old Jul 10, 2013 | 11:21 AM
rebelhell's Avatar
Damnit...
Bends over in resignation.
Old Dec 20, 2013 | 10:43 AM
Prophecy99's Avatar
So I have had a very slight coolant leak and I was almost sure when a mechanic first pointed it out to me it was the same pipe as described in this thread. and so i bought this part,
http://www.courtesyparts.com/21302mb...3-p-45108.html
So once I came around to getting it done by a different mechanic they said I had the wrong replacement part and that part wasn't the one leaking.......
Quote "it is on the other side closer to the radiator"
What does this mean?? I was pretty sure when I first saw this small leak that this was the part, and with this thread an others it almost confirmed my leak here even further.
Could it be I have a leak through a hose and not a metal deteriorated metal pipe? At this time my leak is so bad when I fill up the reservoir it almost dumps right out with in an hour. No heat at idle or coasting.
When I saw a leak pool after parking, the leak looked like it was on the driver side kinda in front of the battery under the intake snorkel area..... do you think that's what he meant?
Old Dec 20, 2013 | 02:54 PM
DennisMik's Avatar
The part you ordered is not the one shown in the photo at the beginning of this thread. You bought a hose for the oil cooler which is down by the oil filter at the bottom of the engine and not seen in the above photo.
As to what is really leaking on your car, I don't know. Unfortunately, your worded description doesn't really help me. Can you post a photo?
Old Dec 21, 2013 | 05:42 AM
car5car's Avatar
I have to replace the hoses too. We can probably just remove them and plug holes. Most cars don't have oil coolers, I was told oil cooler is needed over 100 MPH (Europe highways)
Old Jan 20, 2014 | 12:01 PM
Delirious's Avatar
Coroded tube
This "Lower Oil Cooler Coolant Tube" p/n 140538J10A, it's used on nissan V6 engines from 2002-2009. Mine is coroded and leaking right now and I am thinking of just replacing it with a 1/2" rubber hose and a hose to hose connector for $1.25 instead of $40-$50.
Old Jul 8, 2021 | 10:25 AM
West323's Avatar
Dorman part no
Originally Posted by Noela
Hello,
cheers, Noela
Thats Dorman part No902-098
I know this is an old thread but I wanted to try to help others because my car had the same issue
Old Jul 8, 2021 | 05:37 PM
RA030726's Avatar
I'm nutty for Nissans
That's for the 04-08. Did you install it on a 02-03? I tried and it did not fit.
Old Apr 27, 2022 | 10:16 AM
West323's Avatar
Yes, it looks a little different from factory but it works. Mine is an 03 it was rusted I live in the Northeast
derekinthez
Nov 13, 2022 04:00 PM
MR2 T'd
Jul 9, 2021 05:06 AM
AcuraLegend
Oct 17, 2016 08:47 PM
follyburr
Detailing
Jun 13, 2016 02:06 PM
videomano
Sep 8, 2015 03:28 PM
