Time for a new motor
Old Jul 17, 2013 | 10:39 AM
MAXAQUA's Avatar
Well..My 02 lasted for 109k w/ the oil consumtion issue..But bit the dust this weekend. Im going to do the Motor swap, im shootin for a 04-08 Motor. Anybody know where I could possibly find one in the maryland area for a resonable price?? Im taking all Swap advice too
Old Jul 17, 2013 | 10:49 AM
NmexMAX's Avatar
dot dot dot ...
www.car-part.com
Change the tensioners for sure before tossing it in there.
Old Jul 18, 2013 | 05:27 AM
MrEous's Avatar
^ Jeff™
Eek 109k...did you check/add oil regularly?
Old Jul 18, 2013 | 07:26 AM
nismopc's Avatar
Originally Posted by NmexMAX
www.car-part.com
That is where I found mine. '05 w/72k for $700 locally...
...for me that was the best deal I could find. I did however have to swap a few more parts over from my '02 than initially thought since some of the '05 parts were damaged by the salvage yard. (valve covers, oil cooler lines, engine coolant lines, etc.)
Side note: I also swapped over the following parts:
1. knock sensor (different plug connections between the two)
2. upper/lower oil pan (mine is manual, '05 is auto)
3. fuel rail (different, not sure I had to, but I did)
4. intake plenum (EGR crap on '05)
5. crank sensor (auto/manual)
Those are off top of head. Still in process of swapping...
Updates here:
http://forums.maxima.org/5th-generat...-6mt-pics.html
Old Jul 18, 2013 | 07:50 AM
MAXAQUA's Avatar
Yea man smh.. I checked it atleast once a week.. I had added about 3 qts the day before. I guess that was a sign in itself right there. It burned oil like gas.
Old Jul 18, 2013 | 07:53 AM
MAXAQUA's Avatar
I'll b changing the tensioners an all too, thanks..
So far the cheapest one ive come across is for $1100 with 70k on it.. Personally i still think thats a lil high but im still lookin so hopefully i find somethin else.
Old Jul 18, 2013 | 10:31 PM
MrEous's Avatar
^ Jeff™
Where are you located?
Old Jul 19, 2013 | 01:14 AM
tosheto's Avatar
If your car is manual and the new engine is auto you need your old upper oil pan. I would also swap knock sensor, fuel rails, upper intake manifold and throttle body. You should change the two small oil ring gaskets that go on top of the oil pan and also the two moon shaped gasket located at the front and rear of the engine.
As far as engine goes car-part.com is the best place to look. Find a local place that has a VQ35 with good miles and price and go get it. Many people on here have swapped newer engine in their 5.5 gen Maxima, so there are tons of threads about that. Just look around.
Old Jul 19, 2013 | 06:58 AM
MAXAQUA's Avatar
Im in Maryland the PG county area.
Old Jul 24, 2013 | 06:12 AM
MAXAQUA's Avatar
Still no motor.. but on my old motor I have the spacers/BOP and a R2c intake.. Will the spacers nd BOP work on the newer motors(04-08) or no? I know its something with the EGR or something
Old Jul 24, 2013 | 12:47 PM
nismopc's Avatar
You swap your entire upper/lower intake and throttle body from old engine to the newer one. It removes the EGR crap and yes your spacers/BOP will all work just fine.
Old Jul 24, 2013 | 09:08 PM
MaxinO2's Avatar
If your gonna do the tensioners you should do the guides as well and the chains.
Old Jul 24, 2013 | 09:11 PM
MaxinO2's Avatar
In green are your secondary chains, those are important as well as the guides and tensioners.
I payed someone $100 in labor to come over and do all of it while the engine was out. well worth it.
Old Sep 9, 2013 | 08:40 AM
MAXAQUA's Avatar
Got the motor in las weekend and she running like a champ. No check engine light, I think i might needa tune or something of the sort.
MattWithTheMaxima
Jun 30, 2017 01:06 PM
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
FlaMark
25
Aug 28, 2015 10:15 AM
