knocking noise from rear end (video attached)
Old Jul 30, 2013 | 06:06 PM
CauzinDrama's Avatar
OK so this noise has gotten progressively louder over the past couple of weeks and I don't know the cause of it. It sounds like a bad stabilizer link from the front sounds.... but in the back. It's not the wheel bearings, It's not a big heavy clunk like a strut mount. And I notice it more when I go over little holes or cracks, and not so much when I go over a bump.
Old Jul 30, 2013 | 06:55 PM
03VQMAX's Avatar
First thing, check your spare tire/wheel.
Old Jul 30, 2013 | 06:57 PM
JWatZ's Avatar
I was going to say mounts, but you seem sure it's not. That sounds horrid! Are the struts good?
Old Jul 30, 2013 | 06:58 PM
That was the first thing I checked.
Old Jul 30, 2013 | 07:25 PM
The original owner said they were replaced once but could remember when. I will say the ride is a little bit floaty when going over the expansion joints on the bridge.....
The only noise I've had when mounts go in past cars were chunks..... Not little knocks.... Plus on my max it sounds lower, like under the car kinda sound. Not in the trunk kinda sound.
Old Jul 30, 2013 | 08:12 PM
03VQMAX's Avatar
Check the rear lateral link, could be worn or rear trailing arm bushings. Also your oem jack, trunk lid parts.
Old Jul 30, 2013 | 08:23 PM
Are the bushings even replaceable on the lat link?
Old Jul 31, 2013 | 04:55 AM
03VQMAX's Avatar
Nope, gotta replace the whole thing, but I have on for sale , 4 months old, though it needs to paired up with TDMi QT link, but it formed it's design.
Old Aug 1, 2013 | 04:45 AM
Can that lateral link and QT link the use on a stock suspension, I'm not lowered.
Old Aug 1, 2013 | 06:08 AM
03VQMAX's Avatar
I'm pretty sure it can be used, ask Steven from TDMi
Old Aug 1, 2013 | 07:42 AM
Holy f@#$.....last nite I had the wheels to poke around and see if I can find an issue. I thought at this time it would be a good idea maybe put my spacers on , so I installed the extended studs and wheel spacer on the passenger side, mounted the tire, lower the car, took a step back and saw that it was not flush with a 20 millimeter spacer.
It actually is about the same as a driver side right now that does not have a spacer........ Seems like my axle beam is off center? I haven't hit anything and to my knowledge it was never in an accident before I bought it. Do you think this contributes to my knocking noise somehow
Old Aug 2, 2013 | 07:10 PM
ok so I fixed the knocking noise. Turns out the passenger rear had brake pad shims that were the wrong ones for the pads I have. That pads were sitting loosely within the shims, causing the noise.
Now I have to figure out the axle that doesnt seem centered?....Can the be adjusted at all. From the looks of it Id say no but I might be missing something.
Old Aug 2, 2013 | 07:26 PM
03VQMAX's Avatar
It can be adjusted with the qt link, I have the same issue but I hit something back it 2010 with the right side of my vehicle and bent my beam itself, ain't that off so it doesn't bother me because I'm not paying $552 for a new one.
Old Aug 2, 2013 | 07:34 PM
Ok I just might leave mine as it is then. Its not chewing up the tires and not out of alignment. I want to save money for future mods, (torgue link and exhaust....)
Old Aug 2, 2013 | 08:05 PM
03VQMAX's Avatar
Off centered rear beam will leave your steering wheel not straight, but that's the only down fall
Old Aug 2, 2013 | 09:35 PM
Right, it would throw off the thrust. But my Shyt is dead on. Leads me to believe that what ever the issue is or was happened before I bought the car and the alignment has been corrected.
Huttig2009
Sep 25, 2015 03:31 PM
JoshG
21
Sep 4, 2015 09:04 PM
wingsfan24
Aug 15, 2015 07:35 PM
Bruceharrison
Aug 9, 2015 07:56 AM
