Got Greddy Exhaust today!!! Have question
I just recieved my Greddy exhaust tonight, just had a question, is there any thing that I should know before doing the install, or better yet, does anyone have a write-up on the install. I'm thinking that it's pretty straight forward, bolt-off, bolt-on... Feedback would be appreciated. . . Thanks.
squirt the bolts with Liquid Wrench before removing the bolts and again when they're off. It'll make it easier to remove down the road if you have to break them loose again.
Squirt the rubber exhaust hangers with WD40 or grease to make it easier to pull off. You might need a screw driver to pry them off.
Does the b-pipe have a res on it? Can you check with greddy if just the b-pipe is available and at what price? Would a stock exhaust bolt on to the greddy b-pipe easily? We don't have a b-pipe avail for our cars... I hear Cattman is working on one though.
Originally posted by PhatGuy
Are these available through you still? What is the current price?
No, full catback only. You can't buy bits & pieces.
Re: Greddy
Originally posted by nvmymax2
When I got my exhaust I had to take it to a muffler shop and have an O2 bung welded into the b-pipe of the greddy because there was no hole for the o2 after the cat.
Re: Got Greddy Exhaust today!!! Have question
j/k.nice new toy~
Re: Greddy
i was just about to say the same thing. yup its true. i had to drive over to a muffler shop to do the same thing and on the way there i forgot to tie up the o2 sensor and it dragged the whole way there!
yeah well it happens to the best of us.
So I'll have trouble installing the exhaust do to the O2 sensor? That means i'll have to take it to the shop, which I really didn't want to do if it was an easy job, Is there any way to by-pass the O2 sensor? Please help, I wanted to do the install today. Thanks. . .
Originally posted by myownnismo
Does it matter where you live if you have a O2 sensor after the cat cause I just got mine today and if I have to do that it's not a problem because I work at a machine shop so I can weld a plug on.
Re: geddy evo
Originally posted by 20thdriven
My install bolt off bolt on in 30min, all O2 sensors are before the cat. the rear section (with muffler) of the system required a lift to allow room to snake the piping through.
geddy evo
Any other tips for me or do I have to pay $100 plus to install at a shop.
Re: Re: Re: geddy evo
what the hell? for any shop this shouldn't take more than 30 minutes!!
if they charge u that much, just do it at home. it's not hard..
Re: Re: Re: Re: geddy evo
Originally posted by irvine78
$100 and plus?
$100 and plus?
Re: Re: Re: Re: Re: geddy evo
They said they would have to look at it first but that's a estimate. any tips for me?
if u look at the GReddy, it's a direct bolt-on replacement...u don't have to fabricate anything to bolt on the exhaust..use the stock rubber exhaust hangers and that's it! takes like less than 30 minutes with a lift and air-tools..
Re: Re: Re: Re: Re: Re: geddy evo
yeah, tell them to stop screwing around by charging u ridiculous amounts..
Jcof88
Aug 3, 2015 10:43 PM
