ODB II pinout / speed signal
Old Aug 24, 2013 | 12:29 PM
ZoharDV's Avatar
Hi everyone,
Im interested in installing a Heads Up Display (HUD) in my maxi.
It should project my speed over the windshield. I found several kits in ebay, all of them require the vehicle's speed information from the ODBII connector. Can someone shed some light on how to figure out which pin provide this signal?
I would be glad to have all of the ODBII pinout decoded as well if anyone has this information.
Thank you
Zohar
Old Aug 24, 2013 | 02:49 PM
DennisMik's Avatar
The OBD port uses a type of data communications to transfer data between the ECU and what ever you plug into it. Nissan uses the ISO 9141-2 protocol which uses pin 7 for asynchronous serial data.
For the pinouts, they are in the FSM. Don't have one? get it here:
http://www.nicoclub.com/FSM/Maxima/2005_Maxima/
Old Aug 24, 2013 | 04:47 PM
knight_yyz's Avatar
Toolie
You can also tap into the back of the cluster
Old Aug 26, 2013 | 10:10 AM
ZoharDV's Avatar
So basically, pin 7 will give an analog signal? How do I translate it to speed?
And where would that be? Where can I find an analog input to interpret speed?
knight_yyz
Nov 1, 2015 01:34 PM
uttadms31
Sep 30, 2015 05:24 AM
Marc2theMax
Sep 28, 2015 08:13 AM
