Infiniti I35 Rack and Pinion Removal
Old Aug 27, 2013 | 10:04 AM
drigj's Avatar
Hey guys,
My power steering lost sigificant amount of fluid the other day, and my rack and pinion leak has progressed significantly to where I need to replace it. The manual calls for removing the exhaust tube, stab bar, and cross-member, but I was wondering if I could remove the tires, disconnect the lines and pull it out sideways. Does anyone know if I will have enough clearance to slide it out of one of the wheel wells?
Old Aug 27, 2013 | 10:39 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/4th-generat...ring-rack.html
Pretty decent write-up for a 4th gen, they're quite similar.
Old Aug 27, 2013 | 11:07 AM
tosheto's Avatar
I did it without dropping the cross member and exhaust, but it makes it a little harder.
Old Aug 27, 2013 | 11:38 AM
NmexMAX's Avatar
dot dot dot ...
Corssmember is very easy to remove. Exhaust/y-pipe, not as much, but if you're taking off the crossmember, might as well do the exhaust since, well removing either or is not nearly as smart as removing both for a job like that.
litch
123
Jan 4, 2024 07:01 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
