2003 with strange symptoms
Old Aug 28, 2013 | 08:30 AM
djengr's Avatar
Hi all
My daughter called this AM that her 2003 max, with 137K was acting strange.
She was driving at a speed around 40MPH, level and straight road, when the Tach read zero RPM. Car would not accelerate, she pulled over to the side of the road and waited a couple of minutes and drove off normal. She reported the engine never died and did not have to start it up before driving off.
no check engine light on, she reported no other lights on the dash like battery, oil etc. (just changed the oil last weekend, it is full)
I have not checked for pending codes but will tonight. My suspect is fuel issue like a filter or pump or a loose connection in the tach circuit. I am not sure what the consequences are if a tach wire is loose.
any suggestion would be appreciated. I will edit post with updates as I dig more tonight.
David
Old Aug 28, 2013 | 08:42 AM
NmexMAX's Avatar
dot dot dot ...
Can't be fuel related, has to be electrical because if the tach read zero and was true, the car would have turned off.
Alternator would be my second guess. Same thing happened in my 4th gen.
Old Aug 28, 2013 | 08:50 AM
Amerikaner83's Avatar
agreed on electrical like alternator...
Old Aug 28, 2013 | 09:33 AM
TallTom's Avatar
I would think electrical like the MAF.
Old Aug 28, 2013 | 11:40 AM
djengr's Avatar
Thanks for the replies, I will focus on electrical.
Where does the Tach get its signal from?
Would a loose position sensor cause the symptoms described, crank position, throttle position, cam position etc. I have not checked to see if there are any codes pending, will do that tonight.
David
Old Aug 28, 2013 | 12:25 PM
Tach gets its signal from the VSS I believe, on the tranny.
If there's no codes then you could just have poor grounding on the instrument cluster itself, and simply loosening and retightening the screws on the back of the cluster has been known to help.
Old Aug 28, 2013 | 04:32 PM
djengr's Avatar
Originally Posted by djengr
Hi all
More information.
My daughter was driving home when the engine died. CEL was set and code P0340, camshaft position sensor.
Searched the forum, this could cause the problem.
I will be checking loose wires in the cluster.
David
More information included above, thanks for the suggestions
david
Mahmuth
Aug 16, 2024 08:23 PM
tarun900
19
Dec 20, 2021 06:57 PM
NewMax03
Oct 7, 2015 08:27 AM
zmcneely13
Sep 26, 2015 02:26 PM
