00-03 Maxima Full LED Tail lights
I've been wanting to do LED turn signal for quite sometimes now. Recently got a decent pair of 5.5th gen tail lights from member here and started using these to Prototype the final product ( will be using SE Tails). There is similar LED tails out there for $250 at eBay, I'd figure this build would be a little bit cheaper plus it can function and look the way I want it. My goal is to make it as clean and OEM as possible. I will be using Phiips Lumiled RED HPWT-DH00 Superfluxes for the brake/stop light and HPWT-DL00 for turn signal.
http://www.philipslumileds.com/uploads/3/DS05-pdf My crude wiring diagram for Brake/City http://i1117.photobucket.com/albums/...ringlayout.jpg http://i1117.photobucket.com/albums/...a5f6123302.jpg http://i1117.photobucket.com/albums/...ba9b9c543d.jpg Red LED with 33 ohm http://i1117.photobucket.com/albums/...c65ffb60f7.jpg with 33 + 220 ohm http://i1117.photobucket.com/albums/...842a7ed8c5.jpg Amber LED With 33 ohm http://i1117.photobucket.com/albums/...adf356a713.jpg With 33 Ohm + 220 Ohm http://i1117.photobucket.com/albums/...edb3245385.jpg http://i1117.photobucket.com/albums/...356a33a726.jpg Taking apart the tail light http://i1117.photobucket.com/albums/...edf89f974c.jpg Damage the lens, the lens was attached using epoxy or some kinda perma seal, so combination heat and gentle prying were the way to do it http://i1117.photobucket.com/albums/...40d0d1967f.jpg What it look like with the stock tail lens http://i1117.photobucket.com/albums/...79c6d27321.jpg http://i1117.photobucket.com/albums/...85952497dc.jpg Thinking of replacing those red and amber lens with smooth Red and amber polycarbonate ones. Most OEM application have smooth outside lens |
nice work, post your progress and final results.
That's a lot of work for what it's worth! aka dedication |
good job!
I am very interested to see the finished product. Good luck!
Very cool. Subscribed.
I came in here expecting some ebay junk tail lights ......
However, these look boss A.F! In For Fin |
Nice job, keep up the good work!
Wow it looks great, and i'm not really into light mods, but I really like this.
Good work!
awesome dude! hope to see finished pictures, bravo!
this is great, I hope the finished product will turn out nice. good work so far man!
Originally Posted by picnik99
(Post 8845757)
any updates on this project?
5 Attachment(s)
Ok,
I finally able to spend more time on my own project now...yeahaa. so, for this LED project, I have few scenarios but now sure if it is the right thing to do.. I'm using collimator lens out of flash lights, you can find these at Ebay and other online LED shops. One of the best OEM LED tail lights is FX35's tail IMO. I'm trying to duplicate that performance using Collimator lens. Since the LED has 60 degree viewing angle already, I'm going to see if I can play with the focusing the beam by varying the distance between the collimator and the LED and find the perfect balance between intensity and uniformity. 1st option Basically use the exisiting brake and turn signal bucket/area and fill it with LED. Top is brake/city light, bottom is turn signal, bottom left corner is reverse light. Attachment 23585 Attachment 23586 2nd option, basically like option # 1 but with tinted lens. Looks really good IMO, although the tint is a little too dark for my taste Attachment 23587 3rd option, A complete redesigned look. the 90 degree "Y" is the turn signal, inspired by the Lamborghini Aventador tail light design. The rest will be brake/city light with diffused lens ( no collimator). This can be done in red transparent lens and tinted lens on top or whatever color. I want a complete different look, but this design might be trying a little too hard...... Attachment 23588 Attachment 23589 It's going to be totally new look, but not sure if it goes together with the car..... |
Thats some fine work youve done right there. I like the uniqueness of the y and I feel that it would look sweet when driving at nighg. However the tinted lens looks better for daytime use IMO.
Cant go wrong with either though because of they both are nice looking! |
is it possible to just fill it with red led's and wire it so it acts as a 3 way lamp? running/brake/turn? i always wanted to do that but im not very skilled in this area
Originally Posted by J3macks
(Post 8948242)
1 Attachment(s)
Here is more of a conventional look. Blue section in the middle will be clear turn signal. Looks simple and clean plus the possibility to do sequential turn signal
Attachment 23580 |
im diggin it!
Nice work brother!!
Looks good so far
7 Attachment(s)
Finally decided to use the OEM lens. It looks so much cleaner. Still using collimator to get better focus.
Turn Signals CREE P4 at 40ma. Bare LEDS Attachment 23446 With Collimator Attachment 23447 Carbon Fiber strip (.060") on Acrylic lens for Parking Light, HP at 40mA Bare LEDs + Collimator Attachment 23448 Attachment 23449 Attachment 23450 Attachment 23451 Final Design Attachment 23452 |
Pretty nice! Can't wait to see the finished project!
I want to preorder a pair please. Thanks.
5 Attachment(s)
Got one brake light almost done. 21 LEDs, 2.7 Vf, 38mA using 33 ohm every 4 leds + 270 ohm for the last LED. 38mA seems really bright to me. I compared them to my Sienna OEM brake light and these are almost double. A stock brake bulb is typically 250-300 lumens. HPWTDH00 is 5 Lm at 70mA. Can I assume that the Lm is linear as the current goes down/up? .071 mA = 1 lumen?? thus 38 mA = 2.71 lm. If I have 21 bulbs that would be 21 * 2.71 = 57 Lm. This can't be right. It is brighter than my 21 W (250 Lm) OEM brake bulb for sure. Is there anyway to approximate the LED lumen output?
Attachment 23274 Attachment 23275 Attachment 23276 Attachment 23277 With Lens cover Attachment 23278 |
That's blinding!
Excellent work. For aesthetics, I liked the look of the tinted covers. It doesn't seem too dark to affect visual performance and with leds beneath it, I think it would be clearly visible.
Wow great work!
4 Attachment(s)
Stock Brake lights vs LED.
Attachment 23257 I decided to use the middle section between the brake and turn signal for Parking/City Light Attachment 23258 Attachment 23259 Just got gluing turn signal LED to collimator and ready for wiring. Attachment 23260 |
These are incredible.
When do they go on sale? Lmao
Gluing, cutting wires, soldering takes hours. Custom built one of these will be too much money I think unless I can figure out away to mold the collimator to the acrylic base and use flow oven with custom PCB to place the LEDs and Resistors.
I'll have seperate power supply unit that contain Vreg, Caps, and Diode as seperate unit. |
8 Attachment(s)
Got the turn signal wired.
Attachment 23224 Attachment 23225 Attachment 23226 Added shield for the middle parking light to reduce the light bleeding. Attachment 23227 Attachment 23228 Attachment 23229 Attachment 23230 Attachment 23231 Overall I'm pretty happy with how it turns out. Will build Vreg+Caps+Diode on seperate circuit and I can't wait to test it on the car. |
Awesome project. Loving the updates
Not sure if this is the right thing to do, but it looks pretty good.
Plastidipped bezel. This is the first time I used plastidip and it is very forgiving. It has a nice texture too. http://forums.maxima.org/picture.php...ictureid=39947 http://forums.maxima.org/picture.php...ictureid=39948 http://forums.maxima.org/picture.php...ictureid=39949 |
What color did you decide to go with?
Originally Posted by dfj240
(Post 8954006)
It'd sure be cool to check this out tomorrow when I'm getting my headlights from you. :)
Originally Posted by Genes1s
(Post 8954094)
Color for?
(Post 8954356)
The bezel. You said you plastidipped it. I was curious as to whether you used a unique color or just went with black.
© 2024 MH Sub I, LLC dba Internet Brands
