E brake cable replacement?
Old Sep 4, 2013 | 07:17 AM
Bryso21's Avatar
Has anyone had to do this, or knows how to do this? I've heard it's a long job so I don't want to pay someone JUST for replacing this.
I only need the drivers side replaced.
Any productive input would be appreciated
Old Sep 4, 2013 | 06:09 PM
Chris Gregg's Avatar
Get Off My Lawn
Hard? He'll no! Well, maybe.
If you have stock exhaust, you will have to remove it. That can be hard due to old, rusted, seized bolts. The resonator section is the main issue. You can probably work around the b-pipe. You'll need to remove the exhaust heat shields. Once removed, the cable is clearly secured at certain points. Remove the cable toward the front and you won't have to worry about removing the caliper.
Old Sep 15, 2013 | 07:00 PM
Bryso21's Avatar
Sweet thanks a lot. Gonna give er a shot next weekend
Old Sep 17, 2013 | 07:22 AM
NismoAce's Avatar
hardest part about the job is getting the car high enough to really work with the exhaust.
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
schmellyfart
Sep 25, 2015 04:47 PM
homeyclaus
Sep 3, 2015 06:15 PM
kirkhilles
Aug 8, 2015 10:53 AM
