RPM guage not working
Old Sep 22, 2013 | 10:46 AM
AJLO12's Avatar
hey guys,
i recently have to replace the motor in my 2003 maxima 3.5 Everything went well and i got it all back together and started it up today. cranked over on the first try. now i noticed that the RMP guage on the dash is dead. doesnt move at all. has anyone else had this problem? any advice as to where to start to look for the issue? maybe a sensor i missed or need to replace? any help is appreciated.
Old Sep 22, 2013 | 01:03 PM
03GLEmaxima's Avatar
I guess you can start by checking the crank position sensor because thats how you get rpms. But idk if the car would start without it.
Old Sep 22, 2013 | 02:14 PM
AJLO12's Avatar
car just threw a P0335 crank shaft position sensor code. that has to be it! now where is that sensor located?
Old Sep 22, 2013 | 02:23 PM
NYTooCooL's Avatar
maybe this will help or lead you in the right direct direction?
http://forums.maxima.org/5th-generat...e-install.html
Old Sep 22, 2013 | 07:14 PM
I believe off the top of my head its before the tranny meets the block around the flywheel close to where the cranshaft would be. The sensor looks just like the camshaft positon sensors.
Check the connectors and maybe take it out clean it reposition it and try again. Do you have the sensor from the old motor?
Old Sep 22, 2013 | 07:30 PM
AJLO12's Avatar
Yea. I used the replaced it with the one from the old motor. Same thing. Do I'm back to square one.
Old Sep 22, 2013 | 08:02 PM
Possible causes:
Harness or connectors
[The crankshaft position sensor (POS)
circuit is open or shorted.]
 Crankshaft position sensor (POS)
 Signal plate
Try disconnecting reconnecting its ground. Its located next to the front valve cover on top of the timing chain. Then try to disconnect reconnect the harness located infront of the radiator cap to the far right of the o2 connectors
Cotozic
Jun 28, 2017 08:01 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
kenc15
Aug 5, 2015 08:29 AM
