xtd 3.5 rwd flywheel in an 02 6spd problems
Old Sep 26, 2013 | 09:35 AM
20006spd's Avatar
I anticipated having to shim the starter when installing this flywheel him too my o2 sikk speed but I wasn't aware of any other issues. after installing this flywheel I now have no tach the car is hard as hell to start and I have a CPS engine light. any fixes to this problem or does this fly will not work? Thanks in advance im stumped.
Old Sep 26, 2013 | 10:22 AM
Gemner's Avatar
the RWD flywheel has a different timing ring offset than the FWD flywheel which if you didnt deal with it, explains why its hard to start and you have a CPS light
Old Sep 26, 2013 | 10:24 AM
20006spd's Avatar
thanks for the quick response I didn't do any modifications to the timing ring.
is there a procedure on how to fix this?
Old Sep 26, 2013 | 10:33 AM
Gemner's Avatar
search for super old threads from SR20DEN, I think he was the first to make the adaptation. I dont know exactly what you have to do, possibly shim the timing ring, as well clock to the proper FWD alignment, maybe something else? The starter ring gear is also smaller on a RWD flywheel (124 teeth RWD vs 125 teeth FWD) which might cause you some grinding noise. It would certainly help you if you still have your FWD flywheel to compare dowel pin/timing ring location and distance from crank mounting surface to timing ring. There are a handful of threads covering the issue, might be a couple hours of reading to make sure you get it right.
Old Sep 26, 2013 | 03:42 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/all-motor/373331-mfa60.html
http://forums.maxima.org/all-motor/6...-z33-350z.html
Old Sep 27, 2013 | 04:03 AM
20006spd's Avatar
thanks for the help guys I relocated the CPS shimmed the starter last thing to do is take trans out and clock flywheel this is the part I'm a little unclear about
Old Sep 27, 2013 | 07:29 AM
Gemner's Avatar
I think this is the part you really need to have a stock FWD flywheel lying around for. If you do, you should be able to just match up the timing rings on them with respect to the stock dowel pin location. If you dont have one laying around maybe you can find a picture of one online?
Old Sep 27, 2013 | 03:20 PM
20006spd's Avatar
where is the dowel pin located?
Old Sep 27, 2013 | 05:49 PM
TriniSpeC's Avatar
tdc markings might be different but should be similar for all flywheels. Follow jwt's instructions..
http://www.jimwolftechnology.com/wolfpdf/vq35_rwd_cas_position_check.pdf
I am about to do this later this week with a jwt rwd flywheel and 350zde clutch. Did you just grind the opening for the crank encoder?
Old Sep 27, 2013 | 10:27 PM
SR20DEN's Avatar
VQ Wizard
Some flywheels you do have to move the CPS itself and some flywheels like the XTD can have the timing ring re-shimmed to the correct offset.
MAXSE5SPD
Sep 17, 2022 04:00 AM
-ReLLiK-
Apr 29, 2016 06:25 PM
Maximan190
Dec 16, 2015 06:01 AM
MaxRPM6
Sep 11, 2015 06:56 PM
Maxboy23
Sep 4, 2015 06:04 PM
