2003 maxima e brake help
Old Oct 7, 2013 | 12:08 PM
bikerpro84268's Avatar
ok i have recently replace all 4 calipers rotors and pads on my car i have some tech knowledge but i cant seen to figure this one out guy after installing everything my e brake will not get tight or hold the car i see that the cable at both brakes are moving and wanting to go but just aren't i tried tightening the cable all the way still no help i will get them to make light contact and barley hold i bleed the brake now three time and still no help idk what i'm missing but help will be greatly appreciated
Old Oct 7, 2013 | 08:12 PM
Chris Gregg's Avatar
Get Off My Lawn
How far are the cables moving? It is a common issue on the 5/5.5 gens that the ebrake cables seize up. Typically people report that the ebrake a wont fully release and pads wear quickly. Yours seems to be the opposite issue.
Old Oct 8, 2013 | 01:44 PM
The cable looks like they bottom out all the way. Idk what wrong these caliper are from power stop I just don't know what going on now never seen this happen before they work prior to the change and now nothing
Old Oct 8, 2013 | 06:53 PM
Get Off My Lawn
I bought new rear calipers (thought that was originally my issue - was cable) but, I found that one of them had a faulty e-brake mechanism. It would rotate, but never engage the cylinder. That would be the final necessary test, IMHO. Jack up one or both side tires. Pull ebrake and see if calipers engaging at all. If not, remove calipers and ebrake line, not the brake fluid line. Rotate the ebrake mechanism by hand. If there continues to be little to no movement and/or it rotates extremely easily...then the mechanism is faulty.
Old Oct 9, 2013 | 01:27 PM
thanks i just checked that out look like both side where faulty one more so then the other so just removed them and now having to ship them back for a new set hope that fixes this problem ill keep check back when the new set come in and see if this fixes the problem i having
Old Oct 9, 2013 | 02:25 PM
Get Off My Lawn
I never thought to check my ebrack mechanism before installing either. You better bet I did on the replacement they gave me!!
egali045
Aug 16, 2015 01:19 PM
wingsfan24
Aug 15, 2015 07:35 PM
Samedi
Aug 13, 2015 04:05 PM
09maxshawn11
Aug 9, 2015 01:13 PM
RealityCheck
Aug 5, 2015 06:18 AM
