I will pay top dollar for someone to solder my LED's
Old Oct 15, 2013 | 06:16 PM
Kevin Ellis's Avatar
I purchased a few L.E.D kits from ebay for the dome and door lights and I'm just not satisfied with the brightness or color..I was hoping someone thats good with soldering could make me a dome light using those round little bulbs and soldering them to a panel....
Or if you have an old dome your not using , I will buy
Old Oct 15, 2013 | 06:34 PM
Amerikaner83's Avatar
see my sig...that is all
Old Oct 15, 2013 | 06:57 PM
Amerikaner83:
Thanks but tell me this..the map light, the 01' has one bulb..and the 02' has two bulbs ...do you know if the 02' map/sunglasses holder is compatible with the 01' (spot)...I believe the sunroof switch would most likely be swapped..different wiring or maybe not
but if the the switches can swapped I would buy your kit..can you find out for me if they can be swapped
kevin
Amerikaner83:
01' 2 piece's..sunglass holder and sunroof switch and map light
02' 1 piece..its one unit
Old Oct 15, 2013 | 08:37 PM
you want to swap the map/sunroof control switches? Hmm not sure about that tbh, but I know that the kit I sell will go with either setup...as I have LED panels attached to the BA9 connector for the map light(s)
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Sep 27, 2015 08:37 AM
