2003 Maxima Trouble Codes.po174,po113 x2,po1800 Help Please
Old Dec 14, 2013 | 12:55 PM
AbusiveAlcoholic's Avatar
So like a dumb*** i bought a 2003 nissan maxima for $1300 ( needed work ) figured it would be an easy fix.. i hooked my code reader up to it and these are the codes that came up.. po174,po113 x2,po1800.. Figured a mass air flow sensor... The car was running and seemed to idle fine, But. When i test drove it, It lacked power and seemed as though it was missing very very badly.... well when i picked it up.. I tried to drive it home.. ( had a friend follow in a truck with a tow strap just incase ) got about 2 miles down the road and it stalled out.. so we towed it... as we were towing it.. it would start for a bit with a very low idle.. then it would die... this went on all the way home... ( 30 miles ) last 5 miles it just wouldnt start.. So i put a junk yard Maf sensor in it.. did not do anything! ( Still wont start ) Any thoughts would be awesome.. for i need to figure out what to do with it... do i have a $1300 paper weight?
Old Dec 14, 2013 | 01:14 PM
SSJRICH's Avatar
I don't know about that user name choice...
Old Dec 14, 2013 | 01:23 PM
SSJRICH's Avatar
P0174 and P0113 are MAF - replace with OEM or your won't fix the problem
P1800 VIAS control solenoid
Old Dec 14, 2013 | 01:33 PM
Do I need to relearn or reprogram the computer after installing the MAF? Yeah I know the name is stupid...
Old Dec 14, 2013 | 02:02 PM
george__'s Avatar
Were you drinking and DRIVING!?
Old Dec 14, 2013 | 02:13 PM
SSJRICH's Avatar
No, but I would clear the codes so that you know if the problem is solved.
Slamrod
Apr 10, 2016 05:24 PM
wingsfan24
Aug 15, 2015 07:35 PM
09maxshawn11
Aug 9, 2015 01:13 PM
laparka66
Aug 6, 2015 09:36 AM
