00 Problems starting.
DEk is haveing issues starting, Everything was fine Till 3 days ago I pulled both Crank Position Sensors off cleaned them up and Cam sensor, just to clean metal shavings off. when I crank it, it turns over Great and fast (new starter,Battery) but it seems like theirs no way its gonna ever start even when i kept trying for a good 13 seconds alls it does it make back fire noises in the exhaust and sometimes will stop in middle of turning over like the timing is off,i stop i play with the key get fuel pump primed up and try again and it'll crank right up and run perfect to where ever i take it. then it'll start right up and sometimes it'll do same as above.
whats this sound like to you guys? I pulled codes only o2s bad, i cleaned MAF and seafoamed motor.
litch
123
Jan 4, 2024 07:01 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
