2003 noise coming from under hood
Old Jan 22, 2014 | 02:43 PM
reposition2014's Avatar
I have a 2003 Nissan Maxima an I having so much problem. I have a rattling noise coming from the catalytic converter. An now the check engine light is flashing an the car is jerking an wants to shut off. Does anyone knows what is going on. Did anyone else have any similar problems......
Old Jan 22, 2014 | 03:12 PM
ac max 92's Avatar
If you have access to a scan tool you need to get the codes to help diagnose your problem. Get the codes then check back. It could be any number of things like a bad misfire do to a bad coil or coils, MAF, TPS a bad 02 sensor. It's pretty tough to diagnose until you get the codes and the rattling noise coming from your catalytic is probably just the heatsheild.
Old Jan 22, 2014 | 03:52 PM
Bass_Addiction22's Avatar
Had a similar issue, i had bad spark plugs and coils. Replaced them and haven't had that issue since. Hope that helps.
Old Jan 22, 2014 | 04:36 PM
IceBerg's Avatar
Sounds like you're misfiring and may have a bad cat as mentioned before get those codes ASAP
Hondarydr
Dec 30, 2024 06:15 PM
Starrider
Sep 17, 2015 07:26 AM
Jeffesernia11
Aug 23, 2015 06:09 PM
egali045
Aug 16, 2015 01:19 PM
wingsfan24
Aug 15, 2015 07:35 PM
