widest rims possible?
Old Jan 18, 2002 | 10:49 PM
myktek's Avatar
what's the widest rims u can put on a 5th gen. . with eibach/tokico combo. . .19" rim. . .19x8 front and 19x10 in the back????
Old Jan 18, 2002 | 10:53 PM
95emeraldgxe's Avatar
yor nuts!!! its gonna burn loads of gass to move those heavy suckers......
Old Jan 18, 2002 | 10:56 PM
BigDogJonx's Avatar
Re: widest rims possible?
You can clear the fronts, the but the rears will not clear the wheel well, if you hit a bump, you will get rubbing.
Dixit
Old Jan 18, 2002 | 11:10 PM
2001SE's Avatar
and slow acceleration in a drastic way....not worth it, also it will cost you a fortune.
Old Jan 18, 2002 | 11:14 PM
BigDogJonx's Avatar
Hey some people are into straight looks, not performance. Different strokes for Different Folks.
Dixit
Old Jan 18, 2002 | 11:22 PM
myktek's Avatar
yeah, i'm going strickly show
prob get a kit, try to do dual greddy's, and some 19" hre's
to start. . .
Old Jan 19, 2002 | 08:13 AM
max'n out's Avatar
Ok, AH give me the stupeid reason you have come up with to run a wider wheel in the back on a fwd car. And don't get upset. But the widest you could clear the whole way around would be like a 9.5 with a 255 with a small trim job. NO trim job--9 with a 245. Course you could still run a 255 and just listen to it rub slightly when the suspension bottoms out.
Old Jan 19, 2002 | 08:16 AM
ispeed's Avatar
to start. . .
thank you ... I finally got someone who can relate ...
Mine are 19x8.5 with 245 tires ... never rubbed
Old Jan 19, 2002 | 10:20 AM
max'n out's Avatar
So are mine. And when you hit a huge dip you don't see they rub slightly no big deal though.
Old Jan 19, 2002 | 12:21 PM
ispeed's Avatar
seriously, they have never rubbed. I haven't taken a huge hit from a bump/dip but hard turns, speed bumps, dropping one side completely off the pavement at 40 mph ... not once have they rubbed.
Old Jan 19, 2002 | 12:38 PM
Bman's Avatar
Max'n out and ispeed: The difference is almost certainly in what offset you guys are using. ispeed's wheel offset allows him to run those tires w/o rubbing, but max'n out's wheels' offset moves them a bit closer to some interference point (probably the strut or sway bar or something).
Do you know what offset your wheels are (including spacers if you have them)?
Old Jan 19, 2002 | 12:51 PM
max'n out's Avatar
Yes I know what they are. And you can't jump on that excuse since you don't know. The difference is that he has never hit a dip in on the highway like I have. It takes alot.
Old Jan 19, 2002 | 02:27 PM
Bman's Avatar
Oh.
Old Jan 19, 2002 | 09:06 PM
20 MAXIMA 02's Avatar
Friend has 18" enkei rims with corvette size tires on the rear (275) and with 245 at the front.
Old Jan 19, 2002 | 09:07 PM
max'n out's Avatar
Oh.
I appoligize for jumping on you like that, I had a frustrating day, and I'm tired of seeing people jump on a certain take on things without knowing the whole story.
Old Jan 20, 2002 | 12:19 AM
Bman's Avatar
Oh hey, don't worry about it! Actually, after posting I was worried as heck that my "oh" would be misconstrued as "oh please!" when actually I meant "oh, okay."
If I made cars I'd either put on seriously wide tires to begin with, or be darn sure to make it real easy to! ("See page 347 of your owner's manual for guidelines on fitment of 305/30R19 tires on your vehicle...")
Old Jan 20, 2002 | 07:45 AM
ispeed's Avatar
YEAH
no i haven't taken a huge hit. the only thing that might compare is having to run the car off the road with both the front and rear dropping off ... it was hard enough that i pulled over to check the rims and the car out, but it didn't rub ...
Old Jan 20, 2002 | 10:11 AM
Stereodude's Avatar
So does this mean I'll be able to run a 17x8 with 245/45/17's with no rubbing assuming I have the proper offset? (I'm getting SSR Competitions btw).
Stereodude
Old Jan 20, 2002 | 11:10 AM
ispeed's Avatar
Stereodude
yes
Old Jan 20, 2002 | 12:06 PM
max'n out's Avatar
[B
("See page 347 of your owner's manual for guidelines on fitment of 305/30R19 tires on your vehicle...") [/B]
I don't have a page 347? Your saying the manny says we can put a 305/30-19 on? I gotta see this now! Might have to get some new wheels and tires
Old Jan 20, 2002 | 01:29 PM
Stereodude's Avatar
yes
And what would that correct offset be?
Stereodude
Old Jan 20, 2002 | 02:46 PM
max'n out's Avatar
Stereodude
39mm within that range.
Old Jan 20, 2002 | 03:35 PM
RussMaxManiac
Re: Re: widest rims possible?
Dixit
Thats hard to say... Without trying them first. A guy with a 4th gen had 17x10s on the rear of his and he didn't have problems. He had 265 or 275s on the rear and 245 up front. Front was 17x8.5. 5th gens have bigger wheel wells.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
