Stillen RSB questions
Old Jan 19, 2002 | 08:30 AM
makeHerPurr's Avatar
Hello All Stillen RSB Owners,
A couple of questions:
1. Does the bar "bang" against the rear axle under hard cornering or when encountering a big bump?
2. Is it still possible to use the axle as a jack point?
Thanks All.
Old Jan 19, 2002 | 09:42 AM
UMD_MaxSE's Avatar
Got Bent?
1. no banging here.... make sure everything is aligned correctly and tight.
2. If you have enough clearance to stick a jack there, yes. But, don't use the RSB as a jack point.
Old Jan 19, 2002 | 09:53 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
is that why mine's bent?
Old Jan 19, 2002 | 09:55 AM
UMD_MaxSE's Avatar
Got Bent?
hmmm... could be
Old Jan 19, 2002 | 09:56 AM
20thdriven's Avatar
RSB
the car should be mounted directly under
the rear axle. i had to grind off a brake
line bracket for the RSB bracket. i had
the same problem but now the ride and install
is flawless. use factory jack points.
Old Jan 19, 2002 | 11:33 PM
irvine78's Avatar
Re: Stillen RSB questions
Thanks All.
the 'bang' happens if you don't align the bar correctly..make sure the bar clears the rear control arm housing. if u lined up the RSB right under the beam, it won't bang any longer..
u can use the axle as a jack point. but do try using the factory jack points most times..
Old Jan 19, 2002 | 11:35 PM
Telus.net
Re: Re: Stillen RSB questions
Uh oh. I knew something's wrong with my installation.
Old Jan 19, 2002 | 11:44 PM
irvine78's Avatar
Re: Re: Re: Stillen RSB questions
just set the sway bar right under the beam..that will solve that problem..in most cases that is...
Old Jan 19, 2002 | 11:52 PM
Telus.net
Re: Re: Re: Re: Stillen RSB questions
I did everything as the instruction says. But still bang..
Old Jan 20, 2002 | 06:06 AM
soundmike's Avatar
Very sound, Mike
Would you guys care to show some photo's of your RSB installation? I, for one, have no idea what the rear control arm housing is
Old Jan 20, 2002 | 07:04 AM
UMD_MaxSE's Avatar
Got Bent?
http://www.paulwendy.com/maxima/rsb.htm
maxima-junky
Nov 10, 2015 09:12 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Stagnet04
Sep 14, 2015 11:28 PM
