3.0 engine swap problems
Old Feb 25, 2014 | 09:25 PM
4drsportscarenthusiest's Avatar
hey fellas! so im doing an engine swap on my 2000 max. but ive ran into some problems! my max is a 5 speed. and the engine I got came from a 2000 automatic and some things arnt lining up. like the intake manifold has different vacuum hoses and the flywheel and some mounts .. anyone got anything for me?
Old Feb 25, 2014 | 10:52 PM
clintb3astwood's Avatar
Bump for a quick response
Old Feb 26, 2014 | 12:06 AM
I<3 A32's's Avatar
picture of the new engine??
Old Feb 26, 2014 | 08:34 AM
DennisMik's Avatar
I told you about the motor mounts in your other post.
The flywheel is also different between the auto and manual trans, so swap over the flywheel from the old engine.
The vacuum hoses could be the difference between a California emissions and Federal emissions engine. If this emission guess were to be correct, you will need to have the matching ECU.
Old Feb 27, 2014 | 07:22 AM
nsnrider's Avatar
how about you swap over ALL accessories from your old motor to the replacement motor. That includes intake with fuel rails, exhaust manifold, lower and upper oil pans and sensors.
this should be an easy swap. Maybe you should not be doing this if you don't know that the automatic flywheel is different from a manual flywheel.
Old Feb 27, 2014 | 10:08 AM
gapboi210's Avatar
I am curious if you have both engines there why you aren't swapping over the parts that don't fit?
Old Feb 28, 2014 | 10:49 PM
I have everything set except the vacuum hoses.. they are giving me some trouble. my car is from cali. so I have so many extra vacuum hoses to deal with. I should hopfully have it done by tomorrow.
Old Feb 28, 2014 | 10:51 PM
ill post picks when the swap is complete
Finkle
Sep 27, 2015 09:53 PM
95naSTA
Aug 16, 2015 05:03 PM
95naSTA
Aug 16, 2015 05:02 PM
Hawkeye61
Aug 12, 2015 06:45 PM
