2000 Maxima Air Snorkel?
Old Mar 12, 2014 | 11:57 PM
sinditdomo's Avatar
I noticed that the air snorkel isn't properly attached. It's missing the two mounting bolts that attach it to the frame, but if i move it so that it aligns with the mounting holes, it pulls out of the loose plastic coupling thing that connects it to whatever the other thing is (See 6 seconds into the video to see what I'm talking about). Does it have a big impact on my car? Should I take it out? Thanks !
Old Mar 13, 2014 | 02:35 AM
AEKnight's Avatar
Mine did the same thing. I removed the entire "snorkel" and air filter box. Cut the mounting side of the maf sections and put a cone filter on the end. Home made short ram intake. I can send you pics if interested.
Old Mar 13, 2014 | 03:01 AM
sinditdomo's Avatar
Sure, that sounds interesting !
Old Mar 13, 2014 | 04:37 AM
D.Stillwell's Avatar
You can always do an intake and remove snorkel, and just throw a filter on your MAF. Or you can do some more involved work and do a mid-pipe and remove the helmholtz resonator. Another good product is a velocity stack.
Easiest thing for you to do is just do the GAB mod. Basically this just opens up your airbox and you can do it by drilling some holes in it or just cut out a whole piece and leave the filter attached. Search GAB mod there is a ton of info and pics on that.
Or you can get a couple of retaining clips which is what the snorkel is held down with, not bolts. Put em in and then RTV the connection to the airbox and put a clamp behind it once you push it all the way on, that way it wont slide off and hold well. I had to do this a while back myself, my airbox/snorkel was exactly like yours before I started my mods.
Old Mar 14, 2014 | 07:50 PM
Donkeypunch's Avatar
Use a silicone couple on it.
That's your cold air.
You do not want hot air intake and it will be loud with
the cone. I think it was a 3'' and it doesn't move
Old Mar 15, 2014 | 12:06 AM
sinditdomo's Avatar
How does the silicone couple look like. Could you give me a link to one?
Old Mar 15, 2014 | 06:34 AM
foodmanry's Avatar
Da Roller Coaster!
Use a silicone couple on it. That's your cold air. You do not want hot air intake and it will be loud with the cone. I think it was a 3'' and it doesn't move
No and no. I have a homemade short ram intake. No performance loss per my butt dyno. And the noise is not loud at all...hardly noticeable. All the OP needs is the right cone filter and boom! He can make a short ram intake.
Old Mar 15, 2014 | 10:14 PM
Pure rice.
Old Mar 16, 2014 | 05:58 AM
Maverick4189's Avatar
To what all you calling rice?
Old Mar 16, 2014 | 01:28 PM
foodmanry's Avatar
Da Roller Coaster!
Don't worry about donkey punch. He is a real idiot sometimes.
Old Mar 16, 2014 | 01:53 PM
IHAVEA2KMAXIMA's Avatar
Zip ties are your friend.
Old Mar 16, 2014 | 02:28 PM
obviously....
halfpol
Oct 17, 2022 12:16 PM
jholley
Aug 11, 2015 09:38 AM
kirkhilles
Aug 8, 2015 10:53 AM
niZ
Aug 7, 2015 10:18 PM
halfpol
Aug 5, 2015 08:24 PM
