Horrible gas mileage issue
Old Mar 19, 2014 | 07:28 PM
jjubert's Avatar
I have a 02 auto max with 85k miles on it...only recent jobs done has been transmission fluid drain/refill, NWP spacers added, and alternator belt replacement. Ever since, I have been getting very bad gas mileage! since my last refill, I have burned 1/2 tank and only travelled 64 miles, this is beyond insane!!! Any suggestions out there? I've searched threads and haven't seen any situations with this degree of bad gas mileage.
Old Mar 19, 2014 | 07:37 PM
Child_uv_KoRn's Avatar
Bad *** Newb
I've never heard of it that extreme, but MAF is usually the culprit. It's also going to toast what's left of the cats.
Are you sure the tank isn't punctured lol.
Old Mar 19, 2014 | 08:20 PM
DOODOOCHIP's Avatar
Clean maf and change the fuel filter.
Old Mar 19, 2014 | 09:00 PM
Quickywd01's Avatar
Do you have a vac leak after the spacers not being done right? Replace your 02 sensors too.
Old Mar 19, 2014 | 10:42 PM
maxiiiboy's Avatar
Yes, whoever did you spacers didn't do the job quite right ..... just read your own posting and it's obvious.
Old Mar 19, 2014 | 10:57 PM
jjubert's Avatar
I thought of that, but if there was a leak of that magnitude wouldn't at least a code be thrown? My OBDII doesn't reflect any problems
Old Mar 20, 2014 | 09:00 AM
george__'s Avatar
When I had a f7cked up spacer installation I had air leak and car would stall but nothing gas mileage related. Turned out my torque wrench was broken
Old Mar 20, 2014 | 10:09 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
the piece behind the steering wheel is the cause of it. maybe a leak or sensors
Old Mar 29, 2014 | 10:49 PM
jjubert's Avatar
Wouldn't a vacuum leak cause the car to idle funky or stall...because I'm not having any of those problems
Old Mar 29, 2014 | 11:38 PM
dwapenyi's Avatar
Sticking calipers? After a drive, get out and touch your wheels. The sticking caliper's wheel will feel alot warmer than the rest.
Old Mar 30, 2014 | 12:34 AM
jjubert's Avatar
What's the name of the part you're referring to? Nice rims btw
Old Mar 30, 2014 | 12:49 AM
svillegas2253's Avatar
Had very similar issues with my 96 se. Changed the MAF sensor and replaced o2 sensors and fuel filters. That made it a bit better.
Those are very nice wheels. Looking for the same ones for my 03
Old Mar 30, 2014 | 06:26 AM
foodmanry's Avatar
Da Roller Coaster!
If you are sure there are no fuel leaks and no one is siphoning your gas then top three possibilities for MPG that bad...
1. Clogged cats.
2. Stuck calipers.
3. Bad MAF.
In no particular order. Get all three checked and as someone else pointed out the bad MAF and clogged cats can be related. It is possible you have a bad MAF without throwing a code, less possible you have an air leak as that would show up in the performance and more likely to throw a code.
BTW...you never really mentioned any changes in performance.
Old Mar 30, 2014 | 09:13 AM
jjubert's Avatar
1. Clogged cats.
2. Stuck calipers.
3. Bad MAF.
Aside from a 2-3 automatic tranny slip(bought TransGo Kit), that's getting better with the warmer temps here in Houston, the car accelerates fine....I barely touch the pedal and she's humming. I'm going to fill up again today and recalculate the mpg, hopefully it's not as bad as initially stated
Old Mar 30, 2014 | 11:14 AM
foodmanry's Avatar
Da Roller Coaster!
At least check your brakes after doing that. It's an easy check. If you have a stuck caliper they will be almost glowing red.
Old Mar 30, 2014 | 03:17 PM
Lontar1's Avatar
The part name is "JJubert", just messing with you. It has to be a leak, if there are the brakes like others have mentioned the brake smell will tell you, if that's not it, you have a to look at fuel filter etc
Old Mar 30, 2014 | 04:39 PM
jjubert's Avatar
Just got back from a crawfish boil, checked for almost glowing caliper or an irregular scent of some sort and nothing...I calculated my mpg and came up with 14mpg....still bad nevertheless, guess i'll change maf and o2 sensors and call it a day. Thanks for all the input guys it's well appreciated!
Old Mar 31, 2014 | 01:11 AM
dwapenyi's Avatar
......checked for almost glowing caliper or an irregular scent of some sort and nothing......
With a sticking caliper a physical inspection is better than a visual one. Glowing red and smell indicates a severely stuck caliper. A mildy stuck one will not be as noticeable visually. Solution? Touch......each....rim.
captchaos
Mar 15, 2016 12:18 PM
Maximan190
Dec 16, 2015 06:01 AM
2012Maximus
Sep 10, 2015 12:50 AM
dcam0326
Sep 7, 2015 07:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
