5 point grounding kit info?
Anyone that could please help with some direction on hooking up my 5point grounding kit. I got a hks kit but no directions. I have a idea where some go. But i am stumped on some others. Any help would be greatly appreciated....
grounding kit
thanks for info...
5 points ground
I used the 6 gauge, I bought it in autozone.
Read this link
http://forums.maxima.org/audio-elect...other-how.html
Read this link
The exceptions are:
Battery negative to starter/engine block
Alternator.
You usually don't replace those anyhow. Just clean them.
5 points ground
Any vehicle that run with 50 to 60 Amps alternator the recommended wire gauge is 10 , fusible link 14. While 80 amps alternator the recommended wire gauge is 8, fusible link 12.
Just based on experience I would recommend at least 4AWG for the battery ground supplement, starter ground, supplemental alternator ground and transmission ground. Most everything else however, you can get by with 8 gauge.
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
