I need help A.S.A.P. My 2000 Nissan Maxima is throwing me the P1320 code, and nothing else. I have already had my position sensor replaced and my spark plugs. My SES lights starts to flash if I try to accelerate to quickly, and my car runs super rough when idling. My car sounds like it is having mini explosions when I am going slow, and is stalls a lot when I accelerate. About two months ago my SLIP and TCS off light came on, and have not gone off since.
Is this an ignition coils problem? The mechanic has given up on my car. Is worth spending the money for me to fix it? I just want to make sure it is the coils before I move forward.
I had P1320 code awhile ago. The mechanic replaced all 6 Ignition Coil still couldn't clear the code. Luckily, one of my friends changed the Ignition Coil Harness Connectors and the problem solved.
These are the connectors used in A33 Cefiro in Taiwan. They look different than the one used in Maxima, but work perfectly. It's a better solution than replacing the whole harness which is way too expensive.
