2003 maxima 6mt no start
Old Jun 27, 2014 | 06:40 PM
svillegas2253's Avatar
Already changed out the starter twice since the original one was bad initially. But still the car wont even crank. Checked every fuse and relay, even changed out the clutch pedal safety switch. Any suggestions on what I can check next? no codes
Old Jun 27, 2014 | 09:24 PM
Quickywd01's Avatar
Clean the negative battery terminal with sand paper and follow the cable to the block and sand that clean too.
Old Jun 28, 2014 | 09:27 AM
Thats a good one, ill try that now. Thanks
Old Jun 30, 2014 | 02:39 PM
Maxgig's Avatar
Do your lights come on when you open the door? If they don't the problem could be a blown fusible link. I believe on the 03 Maxima that its a 40 amp fuse. I had an 03, 6sp and blew the fuse while giving a friend a jump start once.
Old Jun 30, 2014 | 05:28 PM
Yes it was the 40A fuse that goes to the ignition and the Start signal fuse under the steering wheel. Both of those were blown
wingsfan24
Aug 15, 2015 07:35 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
09maxshawn11
Aug 9, 2015 01:13 PM
MikesChevelle
Aug 7, 2015 05:57 PM
MikesChevelle
Aug 6, 2015 11:36 AM
