Scrapping Noise when turning
I have this weird scraping noise when I make right turns. Not the clicking noise you get from bad axles. Like metal scraping together. I goes away once the wheel is straight. Buddy of mine thinks its the control arms.:confused:
I just fixed that on mine, it was corrosion on the disk brake heat shields/backing plates. Especially if you lift the front of car up, turn the wheels, and hear nothing.
Also check your bearings.
Originally Posted by ajahearn
(Post 8965982)
(Post 8965982)
(Post 8966717)
This is what I was thinking.
Originally Posted by boondoxmax
(Post 8967944)
I thought bearing made a humming noise while driving. This is a scraping noise.
If it's when you're turning I would almost guarantee its those damn heat shields behind the brakes. I took a flathead and covered it with a towel and wedged it in between the inner side of the disc brake and the heat shield on the lower side and the problem has been solved for months. It keeps recurring though and I just have to keep repeating it. I might actually be doing it again tomorrow if you need pics of what I'm talking about.
Originally Posted by dcam0326
(Post 8968199)
(Post 8968199)
Good, always nice to see someone post a conclusion. Glad to see your rides back in working order...
© 2024 MH Sub I, LLC dba Internet Brands
