coolant leak
Old Jul 21, 2014 | 06:11 PM
cmd26's Avatar
coolant leak
my 03 has a coolant underneath the car coming from the metal hose that goes from the radiator to the oil cooler, my question is do i need to drain the rad before i attempt to change this hose?
Old Jul 24, 2014 | 01:52 PM
FanaticMadMax's Avatar
is it really coolant leak or just transmission fluid leak? Since the Radiator itself is sealed and the tranny cooler is built into the radiator which is self contain. So answer to your question depends, what is leaking. if it's a coolant leaking, then you need to replace the radiator since you might have a crack or rupture on somewhere. Now if it's just tranny fluid, which you should know by now it's red, then no needs to drain the radiator but try to find out why it leaking, is it the hose or the fitting is seeping?
Old Jul 27, 2014 | 10:30 AM
cmd26's Avatar
The rad was replaced already correctly it's definitely leaking coolant not transfer fluid the leak is from the metal hose
Old Jul 27, 2014 | 11:15 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
check that the hose is not cracked, if that's not the so issue, then the radiator has a small crack. Look for the whistling noise around the radiator.
Old Jul 28, 2014 | 10:28 AM
Costee's Avatar
Yes. Coolant will spill out anyway as you change the pipe.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
foodmanry
Sep 24, 2015 12:02 PM
Hdnseek
Sep 9, 2015 05:55 AM
