Brake Pad Materials
Old Jan 22, 2002 | 06:23 PM
02VQ35's Avatar
Brake Pad Materials
Whats up everyone. This is my question. I recently installed on my max a set of new Raybestos PGPlus Semi-Metallic brake pads to replace my glazed OEMs. Since I installed the pads, I get all kinds of squealing and grinding noises. So I emailed Raybestos to complain about the problem and they told me that the OEM pads are ceramic and I should have replaced them with ceramic. Is this true? Raybestos told me to return the pads for a full credit and get the ceramic version. I plan on doing this, but has anyone else run into this.
Chris
P.S. - When I installed the new pads, I turned the rotors and cleaned all of the brake parts.
Old Jan 22, 2002 | 06:31 PM
ispeed's Avatar
Re: Brake Pad Materials
Chris
i'm no expert, but there was a thread awhile back about brake pads ...
there was a post saying that squealling comes for not greasing the shims I believe ... just do a search for axxis metal master pads and it should turn up ...
Old Jan 22, 2002 | 06:52 PM
Synki's Avatar
Sometimes semi-metallic pads tend to squeek.
I thought the OEM's were organics? I know when mechanics replace them, they tend to be usually organic pads unless you request something different. I know Wagner pads (for teh max that is) are organic. The OEM's might be ceramic.
Old Jan 22, 2002 | 06:53 PM
djPlayboy's Avatar
Re: Re: Brake Pad Materials
yeah i agree the peps at pepboys told me to grease the shims or they would have the squealing noise
Old Jan 22, 2002 | 06:59 PM
02VQ35's Avatar
I used the shims that cam with the pads, but what kind of grease do i use. Just regular grease or is it a special grease for brakes. I've done brake jobs before on other cars and never had to use this grease. The grease u said fixes the squealing, but the brakes make a grinding or like a really low groan sound also. Thanks for the replies, I apreciate the help.
Old Jan 22, 2002 | 07:04 PM
djPlayboy's Avatar
brake grease it comes in a small package and isnt very expensive 2 dollars i think is what i paid...
Old Jan 22, 2002 | 07:05 PM
Synki's Avatar
Use the Permatex products for teh brakes. That is one of the best, it should eliminate all squeeling.
Did you have the rotors cut?
Old Jan 22, 2002 | 07:09 PM
02VQ35's Avatar
I had the rotors turned, only because I had grazing one the rotors, and a very, very slight warp. The warp and glazing was removed.
Old Jan 22, 2002 | 08:07 PM
ZIPPIN's Avatar
Mauja He Mauja
thats y u go with AXXIS metal masters. i had Raybestos quiet stop rotors and pads on my 4th generation,,they worked great together,,,for my 5th generation, since i was just replacing pads, i went with axxis,,no problems so far,,,driven with axxis with 2000 miles already
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
