OEM Alarm Issue
Old Nov 29, 2014 | 07:18 PM
Professor's Avatar
OEM Alarm Issue
Ok i had my 2000 Max gle almost 9 years or so, it recently just started sounding the alarm like 10 to 15 mins after i lock it, thought it might be ice or water issues with the cold, but it has since hit almost 60f and it still does it, Can anyone help me or point me to the trouble area.
Old Nov 29, 2014 | 07:19 PM
george__'s Avatar
TSB
NTB01009
If either of the following conditions exist on a 2001 Maxima - - The anti-theft alarm activates 30 minutes after parking the vehicle when the map light is on, and the vehicle is locked. AND/OR - The trunk lamp will not light when using the key toopen the trunk 30 minutes after the ignition switch is turned off. the cause may be the trunk room lamp circuit connection to the battery saver feature of the Smart Entrance Control Unit (SECU). If either of the conditions described exist, performthe Trunk Room Lamp Circuit Re-routing Procedure in this bulletin to connect the trunk room lamp circuit directly to a battery circuit. A Sub-harness kit consisting of two wire tap connectors and a sub-harness wire is available to complete the re-route procedure. When the trunk room lamp circuit re-route procedure is complete, use the Confirmation Test in this bulletin to verify the incident is resolved. See this bulletin for detail.
Old Nov 30, 2014 | 03:56 PM
Professor's Avatar
Well i resolved the problem, All i did was remove the bulb in the trunk and it has not once went off again.
pktaske
May 6, 2016 07:49 AM
-ReLLiK-
Apr 29, 2016 06:25 PM
captchaos
Mar 15, 2016 12:18 PM
aminus21
Sep 12, 2015 04:53 PM
pktaske
Sep 4, 2015 08:40 AM
