"Whisking" noise while driving
Old Apr 7, 2015 | 08:46 PM
GLB07's Avatar
Ok Guys, I have officially exhausted all my thoughts on what this problem can be.
I've had this issue since last year coming from what seems to be the passenger front side, the sound is very similar to a paper clip scraping the rotor and only happens when moving (gets quieter upon applying brake but doesnt stop completely) does not stop on any turns.
Here is what I have done thus far to address the issue
Passenger Side:
Brand new brake pads/rotors
Brand new hub assembly, ball joint & axle
Driver Side:
Brand new inner tie rod (driver side)
Checked:
For bent dust shield
IDK what can be causing this noise at this point but its driving me CRAZY! please help!
Old Apr 7, 2015 | 08:59 PM
chrome91's Avatar
sound like wheel bearing noise?
Old Apr 7, 2015 | 09:04 PM
GLB07's Avatar
wheel bearing replaced with hub assembly
Old Apr 7, 2015 | 10:27 PM
maxiiiboy's Avatar
Check you engine mounts. The one on the passenger side first. My passenger-side mount was lisping (and clunking before) I replaced it. Took me a long time to diagnose ......
Old Apr 7, 2015 | 10:32 PM
mclasser's Avatar
Exhaust shield rattling or sticking caliper?
Old Apr 7, 2015 | 10:35 PM
GLB07's Avatar
Will have engine mounts checked out. Would this be affected by movement though? As I only hear the noise when the car is moving
GLB07's Avatar
checked both, no issues there.
Old Apr 8, 2015 | 10:40 AM
Montego Murph's Avatar
How about the brake backing plate, is it maybe rubbing just barely against the wheel?
That, or... pop the wheel off and check the brake pads. Once time I had a brake pad shim work its way free a month or so after it was installed, and it would rub ever so gently against the rotor hub.
Old Apr 8, 2015 | 11:32 AM
GLB07's Avatar
Checked the plate. doesnt seem to rub.
UPDATE: I jacked the front right side tire up only, put the car in reverse to let the wheel spin. The noise is definitely on that side, on that tire.
One thing I am noticing though is the sound isnt constant, when i first drive the car the noise isnt there, i can turn, accelerate, stop etc no sound, about 10 mins later, the whisking noise starts again. The noise wont stop/start again until I am driving again (same process)
Old Apr 8, 2015 | 05:51 PM
maxipower's Avatar
take the tire off and spin it again without the tire,,if it happens it s a defective new hub bearing,,make sure u put the lug nuts on the hub so the rotor won t rattle
Old Apr 8, 2015 | 06:00 PM
GLB07's Avatar
Sounds good. Will try in the AM. I would hate the hub bearing to be defective, I went with the suggestions on the board going with the Timken brand.
Old Sep 9, 2021 | 11:12 AM
meg86's Avatar
Did you ever figure this out??
Did you ever figure this problem out??
Passenger Side:
Driver Side:
Checked:
Old Sep 9, 2021 | 11:13 AM
meg86's Avatar
I’m just wondering if you ever figured this out I’m having sad issues
Old Sep 9, 2021 | 02:39 PM
uptownsamcv's Avatar
gotta make sure you don't over tighten axle nuts, it can cause premature wheel bearing wear.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Maxie40
Sep 14, 2015 11:28 AM
